Search Forums | Classifieds (147) | Skins | Language
Building a bridge in pasture...telephone poles?
WeaveFarmer
Posted 3/15/2015 10:11 (#4454789)
Subject: Building a bridge in pasture...telephone poles?
Boone Co. Iowa
Hi,
Bought a farm on Friday, first farm I've ever bought. Has 65 acres currently tillable, 55 acres in CRP, and 40 acres of pasture. I was thinking about building a few places to cross the creek that goes right through the middle of the pasture. (think of 4 40s, in the shape of a backwards capital L).
There would be a fair number of spots that are probably 30 ft. across, and I was reading online that some folks have made them with telephone poles. There is currently a big telephone / electricity project going on, and I would GUESS that they will have some old poles that they want to get rid of....
Mainly thinking of gator and jeep wrangler crossings....anyone built a bridge w/ telephone poles before???
iseedit
Posted 3/15/2015 10:22 (#4454801 - in reply to #4454789)
Subject: RE: Building a bridge in pasture...telephone poles?
central - east central Minnesota -
WeaveFarmer - 3/15/2015 10:11 Hi, Bought a farm on Friday, first farm I've ever bought. Has 65 acres currently tillable, 55 acres in CRP, and 40 acres of pasture. I was thinking about building a few places to cross the creek that goes right through the middle of the pasture. (think of 4 40s, in the shape of a backwards capital L). There would be a fair number of spots that are probably 30 ft. across, and I was reading online that some folks have made them with telephone poles. There is currently a big telephone / electricity project going on, and I would GUESS that they will have some old poles that they want to get rid of.... Mainly thinking of gator and jeep wrangler crossings....anyone built a bridge w/ telephone poles before???
I haven't really, well, in my older age - used to as a teenager . ..  . not good results.
The concern with old used poles - the structural integrity is likely all used up, that's why they are being replaced. Also, you build it with intentions of only a ATV or UTV using it and pretty soon, someone with heavier equipment/vehicles are using it (Think Emergency Responders). If you do build using used wood - post the warning signs, for others that may not know what you did.
Or, do it right and consider a used semi frame or rail car frame as a bridge. Use care and think of all the possible, what'if's for later in that bridges life span . . ..
Herdboar
Posted 3/15/2015 10:26 (#4454811 - in reply to #4454789)
Mankato MN; Casa Grande AZ
I wouldn't build anything without checking the rules at the county first.
paul the original
Posted 3/15/2015 10:29 (#4454820 - in reply to #4454789)
southern MN
Pick one spot and build a good, sturdy crossing. Not worn out old telephone poles.
After getting the county/NRCS permit.
Paul
stevebrownia
Posted 3/15/2015 10:36 (#4454833 - in reply to #4454789)
south west iowa
How big is the creek? How much water goes down it in a big rain? We put in some big tubes if put in right will last a long time. Spend the money to do it right the first time and make it bigger than you think you need.
aray63
Posted 3/15/2015 10:37 (#4454836 - in reply to #4454820)
barry county mi
after all gov crap are gotten can you make a large culbert work .we bolted hog huts together and made a good crossing a preaty wide dranage ditch they run combines across. Help build a lot of that sort of thing when we were building I 79 back in the early 60s . good luck archie
Supa Dexta
Posted 3/15/2015 10:37 (#4454837 - in reply to #4454789)
NS Canada
How deep is it? Fast flow? I'd just make a shallow crossing with rock if its not too bad and isn't gonna wash away every year
Jim
Posted 3/15/2015 11:47 (#4454994 - in reply to #4454837)
Driftless SW Wisconsin
+1. Think about a future flood.
jc1206
Posted 3/15/2015 12:01 (#4455025 - in reply to #4454994)
northern IL
Don't waste ur time with poles .
If you want a bridge take an old semi flatbed and put concrete blocks under the edges and drape it across . Truck load of 2" rock on each side to get to the trailer with your your jeep. Concrete blocks will get you 2' above the creek and it will be over 45' + wide oved a 30' creek . You could do it cheaper now with scrap iron down $100 per ton.
69plowboy
Posted 3/15/2015 12:43 (#4455093 - in reply to #4454789)
would a Missouri crossing work that's what we call them in Iowa?
Galaxie64
Posted 3/15/2015 12:55 (#4455124 - in reply to #4454789)
WY, OK
We had several built with power poles for the bottom stringers, used RR bridge planks over the top.  They work fine until they don't.  After had one fail about 10 years ago every bridge is replaced with culverts now.
Cattle Feeder
Posted 3/15/2015 12:58 (#4455134 - in reply to #4455093)
Line those with out hog slats and that works well.
Herdboar
Posted 3/15/2015 14:57 (#4455322 - in reply to #4454836)
Our township has an old cartway with 2 upside down cars with their doors taken off, in the bottom of a ravine for a culvert!
Rules? We don't need no sinkin' rules!
NoTill1825
Posted 3/15/2015 15:13 (#4455346 - in reply to #4454789)
NC Indiana
Could you just slope the banks and put a stone base in and have a ford?
Riverbottom30
Posted 3/15/2015 17:12 (#4455560 - in reply to #4454789)
Like has been said above, Missouri crossing usually work well. I put a bunch in for a guy on a pasture through a creek that was probly 50-60 ft from top of bank to top of bank. Guy is real happy with how they work. They were funded by NRCS. Main thing is dig down all the way to solid clay. The creek I was working in had about 2' of nasty mud and then good solid clay. Put in RR3 to 6" below water flow grade. Then filled up with CA6 to 2" below water flow. Key is to keep it just below the flow so it doesn't wash out. The creek these were put in really gets to raging at times and they have help up great. Been a few years since I did them but if I remember right they were around $3500 per crossing for supplies and labor. Took about 2 days each. (One guy with excavator)
JD_Cattle
Posted 3/15/2015 19:48 (#4455891 - in reply to #4454789)
Wright County, MN
My cousin used an old semi trailer that was completely shot, but has a good floor.  Not sure how he put it in place though.
Big Swede
Posted 3/15/2015 21:18 (#4456204 - in reply to #4455891)
SW So Dakota
I saw a bridge built out of 2 irrigation spans set side by side with some sort of decking over the top, like angle iron and expanded metal on top of that with side rails.
