Search Forums | Classifieds (5) | Skins | Language
T7 185 new holland help!!!!!
redblooded
Posted 2/22/2015 01:57 (#4404283)
Subject: T7 185 new holland help!!!!!
Shelburne Ontario Canada
Plowin snow guy i run with tractor has codes 2568 ,2567, 13005 anyone access to such info wont move blinks N and beeps
Chuck
Posted 2/22/2015 05:36 (#4404315 - in reply to #4404283)
Subject: RE: T7 185 new holland help!!!!!
Wolcottville,Indiana
I have don't have a t7 but would check the transmission oil level, but sounds like transmission electric box or switch on the clutch petal. this is just a guess before the boys who know what to look for chime in. My one ct Chuck
Jay NE Ohio
Posted 2/22/2015 07:10 (#4404414 - in reply to #4404283)
northeastern Ohio
My guess: left hand reverser. Had one go bad on a T6 and it would blink N.
mattb
Posted 2/22/2015 07:51 (#4404467 - in reply to #4404283)
ionia mi
don't remember the code but my puma did similar thing when the park lock froze up
look in you manual and there is a process two unlock it in the electronics
you only get first gear but it will move
scott nelsen
Posted 2/22/2015 07:52 (#4404470 - in reply to #4404283)
Leeds, North Dakota
Ron is alternator charging? belt in good condition? Scott.
redblooded
Posted 2/22/2015 11:33 (#4404943 - in reply to #4404470)
Voltage on dash looks good altenator everything look good as far as wires go just undid park for now an pulled it to where it needs to be . i thinkin tranny controller is screwed or bad wire somewhere but hard to figure out in a snow bank!
Followme
Posted 2/22/2015 15:36 (#4405392 - in reply to #4404943)
Litchfield, NY
Power command or Auto command?
mike10
Posted 2/22/2015 16:25 (#4405500 - in reply to #4404283)
The first two codes are indicating low charge pressure. The third code is indicating the sence voltage is not correct. Either the charge pressure sender is bad or you have an electrical issue with the sence voltage.
