Search Forums | Classifieds (89) | Skins | Language
Pressure Washer Venting
golfnut
Posted 2/18/2015 22:37 (#4396995)
Subject: Pressure Washer Venting
Central Nebraska
I broke down today and bought a new hot water pressure washer.  Its a Shark/Karcher 3.5gpm/2000psi electric unit with a diesel burner.  I'm anxious to use it  but need to figure out exactly where I want to install it and then I need to vent it to the outside. Does anybody have pictures of how they vented theirs and along with any suggestions?
deereman05
Posted 2/18/2015 22:47 (#4397011 - in reply to #4396995)
Subject: RE: Pressure Washer Venting
Your moms house
Put wheels under it so you can take anywhere you need it that has 220
biggrntractor
Posted 2/18/2015 23:06 (#4397045 - in reply to #4396995)
Northern Illinois
We mounted ours on the wall with a 100' of hose on a reel and we have a additional 100' if needed. Its a LP machine, 4 gpm @ 4000 psi. We have a 4x8 area under it that I tapered to a floor drain. After the picture was taken we ran a 8" stack through the ceiling and roof.
(10.15.14 176.JPG)
(10.15.14 203.jpg)
Attachments 10.15.14 176.JPG (92KB - 470 downloads)
Attachments 10.15.14 203.jpg (152KB - 471 downloads)
collegeboy
Posted 2/18/2015 23:26 (#4397067 - in reply to #4396995)
Slicker than a Yes album.
Make sure you put a blocker up-roof from it so sliding snow won't knock it loose.
(37043.jpg)
Attachments 37043.jpg (61KB - 540 downloads)
fuelfarmer
Posted 2/19/2015 01:12 (#4397154 - in reply to #4396995)
Virginia
iseedit
Posted 2/19/2015 06:19 (#4397266 - in reply to #4397154)
Subject: RE: That's not right . . . . .
central - east central Minnesota -
that set up risks pushing the boiler exhaust back in the building . . . . wouldn't be allowed here, per code.   And, just saying - it's your set up and your building - your decision, only pointing it out for others to not consider your set up.
iseedit
Posted 2/19/2015 06:21 (#4397268 - in reply to #4396995)
golfnut - 2/18/2015 22:37
Twp has a new one installed and the instructions give the necessary vent pipe size and such. Otherwise, pretty straight forward. Pipe up through the roof. Ours has power damper, to close to conserve heat and such. It's also a 12 inch pipe - but ours is 400,000 but unit (5gpm @ 1500 psi). Go online and you should be able to find the directions on needed venting.
biggrntractor
Posted 2/19/2015 06:40 (#4397304 - in reply to #4397067)
Northern Illinois
What did you use ? I couldn't find a jack I really liked or that was worth a darn to use on the steel roof.
paul the original
Posted 2/19/2015 06:55 (#4397335 - in reply to #4397266)
southern MN
Edit - oh, got it, was looking at the chimney itself, missed the dual units on the same flue. I understand now.
What part is wrong? Depending on his roof height, he might be tall enough to clear the peak of the roof and thought that was a key, to get a certain height relative to the peak?
I'm just asking, I don't know much on this and want to learn....
Paul
Edited by paul the original 2/19/2015 06:58
collegeboy
Posted 2/19/2015 07:02 (#4397352 - in reply to #4397304)
Never did anything quite yet. A simple "V" screwed into the steel roof would at least divert snow. It generally doesn't pose a problem, but '13-'14 wasn't a normal winter.
NCIA
Posted 2/19/2015 07:16 (#4397390 - in reply to #4397268)
North Central Iowa
Bought a Aladdin power washer. No vent needed. Diesel fuel fired no vent and no smell and best of all no 8" tube going out the shop wall.
Jackrabbit
Posted 2/19/2015 08:10 (#4397523 - in reply to #4396995)
East Central SD
Do they need to be vented vertically? I was going to just use a laundry vent for mine and go out horizontally. Will that not work?
Thanks,
Scott
ontario
Posted 2/19/2015 08:23 (#4397550 - in reply to #4396995)
Here's mine
(image.jpg)
(image.jpg)
(image.jpg)
Attachments image.jpg (98KB - 531 downloads)
Attachments image.jpg (97KB - 463 downloads)
Attachments image.jpg (106KB - 461 downloads)
fuelfarmer
Posted 2/19/2015 08:51 (#4397616 - in reply to #4397266)
Virginia
iseedit - 2/19/2015 06:19
The boiler does not run when using the power washer. Next door there are 88 non vented brooder stoves so the boiler is the least of my concerns. And yes safety is near the top on my list. It comes right after getting something done. :
trapperjon
Posted 2/19/2015 08:53 (#4397621 - in reply to #4396995)
east central iowa
If you would burn kerosene instead of diesel it will burn a lot cleaner so depending on how much you will use it you might not have to vent. Your burner should last longer also. That is what kartcher dealer told me. Mine will burn both but the reliability is so much better with kerosene. You could. Also mount a wall fan like from a hog barn and the just turn it on when you need too but the plus to this idea is if you had a vehicle running in your shop then you could exchange the air that way.
