Search Forums | Classifieds (75) | Skins | Language
oliver 1855/1955 tractors ?
swindave
Posted 1/30/2015 09:23 (#4349421)
Subject: oliver 1855/1955 tractors ?
southwest in
these two models seem to be priced very reasonable, to me,
what the good, bad and ugly on these two?
i know there old, but would be limited use, thank you
Illinois Steve
Posted 1/30/2015 09:26 (#4349429 - in reply to #4349421)
Subject: RE: oliver 1855/1955 tractors ?
North Central Illinois
Motor was the weak link. Many have been properly updated and are fine. Hydraulics suck too
Ed Winkle
Posted 1/30/2015 09:30 (#4349433 - in reply to #4349421)
Martinsville, Ohio
310 Waukesha turbocharged was built stronger than the bottom end.  Most have been fixed.  Most of them died in the first 10 years.  Over Under Hydraul shift is great, rear end OK, hydraulic avg and if not maintained it does suck.  Deere and IH were ahead in hydraulics at that age.
Still many used here every day.
One of the better driving tractors of its day.
Ed
Kooiker
Posted 1/30/2015 09:34 (#4349438 - in reply to #4349421)
The bad is the Waukesha engine and cab if it has one.
The good is everything besides the engine and cab.
The hydraulics on the 55 series Olivers was 20 gpm closed center which is as good or better than everything else that was built at the same time including JD.
The tractor part of 1855/1955 Oliver later became the 2-85/2-105 White which had a Perkins engine in place of the Waukesha and was offered with a better factory cab.    The 2-85/2-105 Whites were very good tractors.
Josh in Pa
Posted 1/30/2015 09:39 (#4349458 - in reply to #4349421)
s.e. Pa
Ed covered them pretty well. 1955's had oil cooler blocks, and so did late or updated 1855's. Comfortable and maneuverable. Not the tractor to hook to a chisel plow and hammer all day. But very good for general use. 12 point rid bolts and 1 piece wrist pin bushings would make me more inclined to buy one. Most probably have had this done. I think you can see down the dipstick hole and tell what rod bolts are in it.
Josh
bshannon
Posted 1/30/2015 10:13 (#4349537 - in reply to #4349421)
Worst tractor we ever bought was an 1855, and it wasn't even the engine that gave problems; clutch, turbo, injectors, even steering spindle broke off. Hydraulic problems were the final straw as no one seemed to know how to work on them. On the plus side the over/under hydro shift was nice;)
shopmanbob
Posted 1/30/2015 11:03 (#4349657 - in reply to #4349537)
I have worked on Olivers for 35 years. I would not own a 1855 Diesel. Seems like the engine had a vibration or something that effected the hydraulics and other parts. The 1755 and 1955 were good tractors. Some trouble with the piston pin bushings if you got the engine to hot. Very nice handling tractors. www.greendrills.com
O.u.and.direct
Posted 1/30/2015 11:36 (#4349718 - in reply to #4349657)
Southwest Missouri
Don't know what you are going to use it for but I think you would be better off in the long run with a 2-85 or 105 white much more refined tractors
zkeele
Posted 1/30/2015 11:44 (#4349734 - in reply to #4349718)
Tennessee
+1
2-105 is a much better tractor.
White Workhorse
Posted 1/30/2015 12:30 (#4349840 - in reply to #4349718)
Sourthern WI
+1 Get a 2-105. Many significant improvements for not much more money. Things are usually cheap for a reason.
olwhda
Posted 1/30/2015 13:03 (#4349891 - in reply to #4349840)
Liberty, MO
Go with the 2-105 , I've had both 2-105, and 2-85, much preferred the 2-105, bought the 2-105 new in February 1975, still got it, but mostly retired to loader and 3 pt blade now.
lfreehauf
Posted 1/30/2015 15:14 (#4350181 - in reply to #4349421)
Ohio
A bit off subject
Olive 1655 was a great tractor. It's been our 'go to' tractor for decades.
