Search Forums | Classifieds (132) | Skins | Language
pole barn split slider doors
jcwag
Posted 12/31/2014 12:14 (#4277139)
Subject: pole barn split slider doors
Upstate Ny
we just put up a 54 foot wide pole barn with split sliders facing the prevailing wind. too cold to pour concrete or secure the bottom of the door, so i just parked a dump truck behind them and ratchet strapped them tight for the winter. any ideas on how to secure the bottom middle of these doors? i am in ny state, and it gets cold, if i pour cement under the door should i go down 4 foot like footings in my area?? we are not going to concrete the building.
Lone Wolf Picker
Posted 12/31/2014 12:39 (#4277188 - in reply to #4277139)
Subject: RE: pole barn split slider doors
Black Hawk County, IA
My favorite way is to drill a 24" hole 4-5' deep, fill with concrete. Beforehand we bend 2 pcs of 1" round solid into big horseshoes. 24" on each leg and 12" across, set when wet just wide enough for the door track to fit between. No more rattling doors. J
Paul(WI)
Posted 12/31/2014 12:41 (#4277191 - in reply to #4277139)
We poured a concrete center post with a slot for the doors to slide in. Its solid but make sure its below your frost level. Ours should have been a ft. deeper. It faces the north and frost will heave it some. Fortunately once winter sets in we don't need to move those doors till spring.
hdfchris
Posted 12/31/2014 13:12 (#4277261 - in reply to #4277188)
Western WI
Lone Wolf, could you send pics of your sliding door anchor, sounds interesting.
Dave9110
Posted 12/31/2014 13:44 (#4277322 - in reply to #4277139)
north-central Indiana west of Fulton
I would pour all the way across your door opening high enough to catch the bottom of your doors. This will hold back of doors so they won't bow, then have an approach out front (your choice of size) to cement in steel anchors and also give you a surface to clean snow easily in front of doors. We never went deeper than 18" directly below doors, and have not had problems. Some like to go more. We have a couple sets of doors like this that are 25 years old. They have RR iron in center and 1" rod bent in middle of each door. The cement all the way across also helps to avoid loss of dirt under doors then having a mud hole there.
(image.jpg)
(image.jpg)
Attachments image.jpg (159KB - 512 downloads)
Attachments image.jpg (183KB - 492 downloads)
hoof5
Posted 12/31/2014 15:12 (#4277516 - in reply to #4277139)
w-c wi
What we did was take 8" pvc pipe or what a 6" square post fits in. Drill hole 4' deep and poured concrete around it and level or 1" above with top of ground, drop 6" post in the hole and we capped the top with metal top and 2 " inches down the side lag screw it and used 2 turnbuckle's, welded the one end to cap on back side of cap so u have more of angle, pull pole out when doors r open and nothing to drive over, if it ever fills with dirt we just vac'ed it out once now in 5 years, just make sure your centered
Rock Road
Posted 12/31/2014 15:14 (#4277522 - in reply to #4277322)
w/c Illinois
I did something like Dave9110 suggested.  I put a wall 6" wide just inside the door that is 3' into the ground and sticks up just high enough for the bottom of the door to slide along.  It keeps the door from blowing into the building when it is released from the center support.  I didn't put any concrete under or in front of the door, but if you go deep enough, heaving won't be a problem.  An extra foot or two of depth on a 6" wall doesn't add much concrete or cost.  It is a bit of a speed bump when entering or leaving the shed. That seems to be the biggest downfall.
Posted 12/31/2014 15:26 (#4277542 - in reply to #4277139)
Had many older style sliders that slid in a poured concrete groove. Most miserable things ever. Dirt and moisture gets in concrete groove and makes doors hard to slide or freezes them completely shut in ice and snow. Keeps them form blowing but that's about it.
Had some newer sliders made with bottom track that slides over rail on bottom when opened. Outside apron and floor are same level poured below frost level. Sank a pipe in concrete and made this receiver style unit for bottom track to slide over. No bump pushing things in the barn everything is smooth and level. Pour some antifreeze in the receiver pipe and no issues with freezing.
Pics are in this previous thread may need to do something different since your not cementing inside. I just don't like having some support that should not be driven over.
http://talk.newagtalk.com/forums/thread-view.asp?tid=23642
NEILFarmer
Posted 12/31/2014 15:59 (#4277605 - in reply to #4277139)
Morris, IL
We poured concrete footings down 4'. Have 2"x2" angle iron with rebar under it holding it in place. Our is 16" wide at the base (we have 16" backhoe bucket) but probably closer 20" at the top. It keeps birds out, keeps lot of snow out, and make getting the doors open in the winter much easier. The center post just bolted to the concrete. I'll attach some pictures.
(DSC05924.JPG)
(DSC05925.JPG)
(IMG_0880.jpg)
Attachments DSC05924.JPG (112KB - 490 downloads)
Attachments DSC05925.JPG (122KB - 474 downloads)
Attachments IMG_0880.jpg (352KB - 432 downloads)
Lone Wolf Picker
Posted 12/31/2014 16:11 (#4277622 - in reply to #4277261)
I'm not home, will try tomorrow. J. Edit Chris look at Dave9110's pics, looks like mine only I only have one longer set where the doors come together. J
Edited by Lone Wolf Picker 12/31/2014 16:13
Gerald J.
Posted 12/31/2014 19:31 (#4278027 - in reply to #4277139)
I saw an adjustable metal center guide at Farmfest several years ago. I found one at a lumber yard in west center MN that week. I wanted another and found I could get it ordered from National or Stanley, so I have another ordered through the local Jewell Farm and Home. I'm sure it can be had other places at a better price. It needs a deep post or a concrete pile to hold it. If pouring concrete its probably not all that better than two pieces of steel pipe bent into U shapes and cast in the concrete. Frost is your enemy so the bottom needs to be below frost.
http://talk.newagtalk.com/forums/thread-view.asp?tid=491802&posts=5...
Gerald J.
Avg. Joe
Posted 12/31/2014 20:49 (#4278210 - in reply to #4277139)
Elmwood, Ne. Just East of Lincoln
This is what I did and it has worked great for 2 years. I put a pipe in the ground in concrete down below frost. Then on the inside of the door a pipe slides up and down that fits just right inside the ground pipe. On my wood frame door I put two flat irons for the pipe to slide in. They are drilled exactly the size of the pipe. I just pull the pipe up and turn it a quarter turn and it rests on the square iron that is welded on the flat iron. A high tech hose clamp holds it up. It is then adjustable so the pipe is held up to the bottom of the door frame for sliding. I welded a point on the bottom of the pipe so it doesn't have to be exact to slide in. If I just get it started in the hole and shake it a couple times, when I latch the outside of the door with an over center latch it usually falls on in. Was wondering if this was going to work whe I did it but so far has worked flawlessly. It's a 30 foot door. Two 15 foot sliders
Edited by Avg. Joe 12/31/2014 20:57
(image.jpg)
(image.jpg)
Attachments image.jpg (92KB - 466 downloads)
Attachments image.jpg (89KB - 421 downloads)
OH Mike
Posted 1/1/2015 22:25 (#4280972 - in reply to #4277605)
NW Oh
+1
rebuilder
Posted 5/15/2015 06:15 (#4570842 - in reply to #4277139)
Indiana
Ralph52
Posted 5/15/2015 07:28 (#4570993 - in reply to #4570842)
Williamsport IN
+1
cdsloop
Posted 5/15/2015 21:17 (#4572343 - in reply to #4277139)
Central NC, Rowan County
