IH 656 PTO Clutch
HOGFARMER
Posted 12/12/2014 09:56 (#4235526)
Subject: IH 656 PTO Clutch
NE OHIO
The PTO clutch is starting to slip on the gas IH 656. Did a complete engine overhaul this fall now this happened. This is a chore tractor not a field tractor but would like to be able to use in on an auger or the grinder mixer. How is this changed or is their an adjustment? Thanks!
Flipper
Posted 12/12/2014 12:10 (#4235707 - in reply to #4235526)
Subject: RE: IH 656 PTO Clutch
Hoffman, IL
PTO is a hyd drive with its own pump mounted on it. Drain the rear end oil and it comes out the back with four bolts. Then can have it rebuilt.
HOGFARMER
Posted 12/12/2014 12:23 (#4235736 - in reply to #4235707)
NE OHIO
Thank you that is the information I needed.
Tim swMN
Posted 12/12/2014 13:34 (#4235872 - in reply to #4235526)
Hendricks MN
There is an adjustment on the rod going into the unit. But if it is slipping already the discs are probably burnt and should be replaced.
Trint
Posted 12/12/2014 14:14 (#4235919 - in reply to #4235707)
North Central OH
If you have a good hill to park it on can pull without draining oil. Be sure to put a gauge on it after rebuild to check hydraulic engage pressure, think mechanic told us 65psi when we did our 686, not sure anymore though.
