Search Forums | Classifieds (103) | Skins | Language
Case 580CK Backhoe questions
ihmanky
Posted 12/4/2014 21:25 (#4220266)
Subject: Case 580CK Backhoe questions
KY
Sitting here with time on my hands, wondering about something. Couple of years ago a landlord who lives several states away wanted to clean up his old farmyard area. Had an old dodge 1 ton truck, a case 580 ck backhoe, and several small 3-point implements well worn out, rusty and broken. The dodge was pretty well trashed, windows all shot out and hood left up on it, just pretty well rusted out. No idea how long it say. The hoe was in average shape then, had been sitting approx 2 years then and was parked due to the flywheel being bad and wouldn't start anymore. Was otherwise working then aside from leaking 2-4 gallons of hydraulic a day or so from various leaks. He wanted everything scrapped, and I told him I'd load it all and take it off if I could haul the hoe to my place. He told me I could haul it all to my place if I wanted, I passed on that and scrapped the rest for him. Fast forward, the machine has been sitting outside one of my sheds for another 3 years, so it's not done anything for 5 now. The engine is not suspected of being seized, think the flywheel (if even that) will solve the start issue. Front tires are foam-filled, so alright. Both rears are flat, one was already and the other has gotten that way over time and are well dry-rotted, 34's I believe. Looks like every hose to the hoe will blow the section pressure is applied as well, so factor that in. So, IF I can get it running with a flywheel (turning it around won't work on these I don't think), new lines, rebuild the valve stack, maybe some used tires for the back, what would be a reasonable amount to spend on this before it wouldn't be worth it's value? How bad is a backhoe to split to do a flywheel and a clutch while I'm in there?
Fingers77
Posted 12/4/2014 21:30 (#4220282 - in reply to #4220266)
Subject: RE: Case 580CK Backhoe questions
IMO for the newer backhoes abailable for reasonable prices, $500 is about too much to spend. It will nickel and dime you to death. Unless it's a job you have a passion to do. Realistically, it's a money pit. If you have the time, energy and hose machine then you might wind up ok.
Timd3200
Posted 12/4/2014 21:58 (#4220359 - in reply to #4220282)
SoCenIL
X2
ihmanky
Posted 12/4/2014 22:00 (#4220366 - in reply to #4220266)
KY
Wondered that too. Don't know what it weighs, but all of that getup together ought to scrap out for over a grand anyway, be a decent start on a running one.
Indianajones
Posted 12/5/2014 05:31 (#4220624 - in reply to #4220366)
I have split my 530 twice for the clutch and it is not a bad job to do, don't even take the loader off. That being said, still sounds like best to scrap it out or part it out. They weigh close to 15k but it will be a constant repair issue on something.
INDY
twraska
Posted 12/5/2014 11:57 (#4221393 - in reply to #4220266)
Wallis, TX
Brother has an older 580 and he said it is getting hard to get some parts for it.
Teeshirtfarmer
Posted 12/5/2014 18:52 (#4222093 - in reply to #4220266)
Semo
Old backhoes go to the farm to die and it sounds like that one did.
