Search Forums | Classifieds (58) | Skins | Language
Loader bucket vs. snow pusher
IowaMark
Posted 11/19/2014 11:22 (#4188033)
Subject: Loader bucket vs. snow pusher
NW Iowa. / SW Arizona
I've got a JD 7130 with a 741 loader W/8' snow bucket. I widen all my tires out to 90" OC this spring to match my sprayer. As a result my tires stick out past my bucket. I haven't pushed any snow with this setup yet as we haven't had enough snow yet. I know it will work as is but am thinking of buying a snow pusher as an option for the loader.
I'm curious with you guys that use snow pushers do you like them better then just a loader bucket? I've talked to guys that use them on skid loaders and they really like them. I looked at one at the Spencer Fair that is made not to far from me. It was an 8 footer but he said he makes an 10' & 12' model also. I would go with the 10' if I did get one. Not 100% sure on specs but I was thinking it would have a 39.5" back with 36"-37" sides. You can put either solid adjustable 2-5' steel reversible cutting edge or a rubber edge. He recommended the steel because if you use the rubber if you push snow when it's wet and leave tracks they will freeze and those humps are hard on the rubber, which makes sense.
I thought the cost was very reasonable $1,400 with whatever style brackets mounted to it. He said for I thought was $225-250 he could make an additional brackets so it could fit either my skid loader or my loader. I'm just afraid the 10' would be to big for my NH L175 skid loader. I'm sure the 8' would work for it but them I'm defeating my purpose.
(image.jpg)
(image.jpg)
Attachments image.jpg (127KB - 763 downloads)
Attachments image.jpg (126KB - 637 downloads)
ricksitzmann
Posted 11/19/2014 11:43 (#4188070 - in reply to #4188033)
Subject: RE: Loader bucket vs. snow pusher
Iowa
I made a pusher out of an old combine tire and two pieces of square tubing.
Absolutely love it for pushing out cattle yards and any area that I don't have rock on. I feel I can do a better job with a bucket on driveways and not dig up rock.
Can move a lot more snow in a hurry with the pusher tho. Sometimes I move the majority with the pusher then come back to clean up with the bucket.
My pusher is 18ft long and only cost whatever two pieces of square tubing and a bracket cost.
Fred
Posted 11/19/2014 12:05 (#4188102 - in reply to #4188033)
south east SD
Local machine shop built this for me. 12 footer and would not go bigger, but not smaller either.
It's on a 7430. I'm thinking it was above $2500? Very well built and it has a curve so the snow doesn't come out the back. It just lift it till the cutting edge isn't touching the ground, have the front touch and go.
Edited by Fred 11/19/2014 13:17
(image.jpg)
Attachments image.jpg (123KB - 534 downloads)
Mark@Northern Iowa
Posted 11/19/2014 12:12 (#4188123 - in reply to #4188070)
Subject: where are the pics :)
Floyd County, Iowa
Where are the pictures. :)
Thanks
TMX864
Posted 11/19/2014 12:19 (#4188137 - in reply to #4188123)
Subject: RE: where are the pics :)
Michigan
Get the pusher, you will be very happy with it. They will move a lot of snow if you can get the traction to push it! 10' might be a little large for your skid steer in a big snow, but would be a very good fit on your tractor.
We have a 12' on a 580 super M backhoe and a 16' in front of a 250 Versatile. We have rubber edges bc we plow blacktop parking lots with them and they work well, however if you are planning on using it around the farm yard I would opt for steel. We had to plow a business lot that had some gravel parts to it and it destroyed the rubber edge in no time.
Edited by TMX864 11/19/2014 12:28
(image.jpg)
Attachments image.jpg (132KB - 554 downloads)
MNredfarmer
Posted 11/19/2014 12:24 (#4188150 - in reply to #4188033)
I have a 10' snow pusher. When it is loaded up with snow don't expect to turn your tractor, even with fwd. I think it is much faster than a loader bucket for a couple of reasons. When I clean the yard with a bucket I start pushing and 15' later I have snow dribbling over the sides. I have to make three trips across the yard to get rid of the windrows of snow. With the pusher I go probably 50' before it dribbles over the sides and it only takes one more short trip across the yard to clean up the windrows. The other thing that saves time is the fact that you don't have to dump the pusher like you do a bucket. You just drive up to the pile, lift and bounce it a little to get the snow off of the pusher.
I should add that a loader with hydraulic self leveling like my skid loader, it's a pain because you have to relevel the pusher every time. My tractor loader doesn't have self leveling so I never have to mess with the bucket tilt. Mechanical self leveling might be ok , but the hydraulic type on the skid loader only levels on the way up but not on the way down.
Edited by MNredfarmer 11/19/2014 12:28
VGL 1
Posted 11/19/2014 12:31 (#4188161 - in reply to #4188033)
On the Delmarva
Pusher's are great. I run pushers on just about everything from loaders, tractors and skids. The only time I use buckets is when I have to move piles, and the blowers won't work for whatever reason. Around here on pavement with short runs your skid would be able to handle a 10' box.
deereman
Posted 11/19/2014 13:11 (#4188226 - in reply to #4188102)
NE SD
What tractor do you have that on? And where did you have it made and how much$$?
Thanks
3500ctd
Posted 11/19/2014 14:38 (#4188357 - in reply to #4188226)
Wisconsin
Last year we picked up a used 16 foot pusher for our Volvo loader and loved everything about it. What used to take 1 to 2 hours with a pickup, now takes 30 min or less. I doubt you will find anyone who likes a bucket better.
remington 17
Posted 11/19/2014 16:35 (#4188521 - in reply to #4188033)
NW iowa south of the CIty :)
http://www.denhartogindustries.com/arctic-assault/
I got a 8 ft on skid loader way faster then a 8ft loader bucket on tractor
the rubber blade does not rip up grass to bad.
Had to buy it from a sales place couldn't buy at factory.Got it in sheldon
across from the Cassy's by the Pamida / Shopko store.
Edited by remington 17 11/19/2014 16:39
shoop
Posted 11/19/2014 18:57 (#4188789 - in reply to #4188033)
M
I had a protec on a skid steer and I didn't like it. I think for most part they are good . I think the mounts were to high . To push you had to have the loader up to high , maybe 6 or more inches up . Once you had it on you couldn't get the door open. I think the other problems might be when to want you want to push with a skis it pushes the most with the boom down and when the pusher was flat on ground the boom was 6-8 up.
John In Ontario
Posted 11/19/2014 19:07 (#4188806 - in reply to #4188521)
Ripley, Ontario Canada
I run an 8 foot on a an 8785 agco allis (135hp mfwd). I could go wider but I do residential drive ways and can't go wider for cars. The snow pusher is way better than the bucket. The skid shoes on the pusher keep you from gouging the ground. The sides let you push a lot further without spilling snow. Since you are putting it on a tractor I would look for a heavy duty one with a steel edge. My 8 footer is a Reist welding with a roto trip edge and the cutting edge is only supported at each end and it is barley strong enough when you catch something. I have bent my pusher. Next one will have the cutting edge supported at least every 4 feet. The tractor has too much mass to stop if you catch something.
The pusher is not as good in really hard snow, the shoes ride over the snow and you have to go get the bucket then.
Combine Pilot
Posted 11/19/2014 20:49 (#4188954 - in reply to #4188806)
Saskatchewan
I have an 8' bucket and a 15' Degelman Speedblade for my skid steer. I talked to a guy about his Speedblade before getting mine. He uses his on a 7230 and loves it, said he never uses the bucket anymore.
Edited by Combine Pilot 11/20/2014 12:33
oldbones
Posted 11/19/2014 21:56 (#4189019 - in reply to #4188033)
Floyd County, Iowa
I built my own pusher for the front of my little 5303 tractor. Started out with a pickup snow blade, put ends on it, made adjustable skid feet, and made the mounts for the loader. Less than $250 in it.
Move a lot more snow in a lot less time than with the bucket, but as mentioned earlier, turning, even with front end in gear, won't happen. I have the steel cutting edge and scalped the grass in places, so I cut a slot in a piece of 2" pipe and put that over the bit. No more moving gravel or sod.
(DSCF0899(1).JPG)
(DSCF0902(1).JPG)
Attachments DSCF0899(1).JPG (138KB - 636 downloads)
Attachments DSCF0902(1).JPG (147KB - 653 downloads)
Uni11
Posted 11/20/2014 08:12 (#4189479 - in reply to #4189019)
http://www.holmeswelding.com/snowdozers.htm
