iowa | I purchased a newholland skid steer from a private seller this weekend. Worked fine when I bought it but having some problems now after only a couple hours use. When starting the machine it wants to creep forward while cranking making it hard to start. If I pull back on left stick it does nt creep. Starts easier. The left stick also is not traveling freely when I pull back on it. I have to pull hard on it to make the left side reverse and then it only reverses slowly. After it started these problems the left side also wants to race forward with no forward pressure on it when I am driving it across the yard. I have to pull back on th left stick a little to keep it from out pacing the right side. The machine has 3300 hous on it and is in avg to good condition. Any experienced l553 owners seen this problem in their machines? Might this just be an adjustment or is my drive motor wore out? |
