| AgTalk Home | ||
which replacement radioJump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
| Forums List -> Machinery Talk | Message format |
| bootheel farmer |
| For jd tractor I can get a delphi (oem) REI from sloan soundtracks from shoup experience with any of these??? Thanks | |||
| durallymax |
Wi | Guessing this is a single DIN slot? I put a lot of Kenwoods eXcelon's in. Really like them. Put eXcelons in some applications and some of their similar units that are not eXcelon's but share a similar appearance and most specs and features with a lower price. The eXcelon KDC-X798 or the KDC-BT758HD are the two I prefer. Unless you are putting in a huge component system with some serious sound, you don't really need the eXcelon. Most of the features it offers over the others, will not be noticed in a tractor cab.
Dislikes
Keep in mind, the above things that I mentioned I like are not necessarily specific to these radios really in any way. You can find these features on many different radios. Finding "tractor style" "heavy duty" radios with all of the above features is not easy though and often gets very expensive. Personally I feel heavy duty radios are overrated. They are not that special and they still fail. Even if they are "tougher", they are drastically overpriced. Installation of one of these will not be "plug and play", but will ber very easy. This applies for any single DIN radio. You will remove the old radio, discard the old "cage mount" if applicable. Then install the cage mount for your specific radio by sliding it into the hole. To hold it in place simply bend the proper tapered tabs over. It should be nice a snug when done. The radio will simple slide into this mount and lock into place. To remove it, you will need the removal tools for the radio so tape them in a glove box or something so they don't get lost. If you do loose them they are not hard to come by. Some radios like the Kenwoods will have a trim piece to snap on that hides the slots for the release tools. The toughest part will be wiring. The new radio will have a diagram but the old radio may not. With some research you should be able to figure out all of the wires. Then you can either splice the wires, or put them into a connector. Your choice. There is not a bagillion wires back there. You need a constant 12v, keyed 12v and ground for most all radios. Some will have a dimmer wire, some will have other wires that may or may not be used, but those are the basics. You will then have a + and - wire for each speaker that you have. Its pretty simple and basic wiring. Often times you can buy a plug for your vehicle/tractor and simply splice the appropriate wires from that plug with the ones from the radio plug. Much easier to do it this way on a bench than crammed up in the radio slot in the cab. Here are some photos and Amazon links(for simplicity, plenty of other places to buy). If you are browsing and comparing audio stuff, I suggest going to Crutchfields site. Its very well laid out with more detail than some of the OEM's. You will notice there is not much difference in appearance between the eXcelon and the non eXcelon. This is the eXcelon KDC-X798 Buy on Amazon This is the KDC-BT758HD Buy On Amazon This is the eXcelon KDC-X998 which is two steps up from the X798. Compare the features to decide. No preset buttons and using the Knob is a big change you may or may not like. Buy On Amazon ![]() This is the KDC-BT958HD which is two steps up from the BT758HD. Compare the features to decide. No preset buttons and using the Knob is a big change you may or may not like. Buy On Amazon ![]() This is the remote that all of them come with. ![]() This is the small Microphone (included with all BT models) for the Hands free Bluetooth calling. It has a small visor clip on it. You can also opt to velcro it to the headliner somewhere. ![]() Good Luck. Edited by durallymax 9/4/2014 00:35 | ||
| rightsaidfred |
Mountain West | REI is as good as anything, if you just want a basic radio that is easy to install and use. | ||
| tedbear |
Near Intersection of I-35 & I-90 Southern Mn. | I can relate to your reference to having a place to brace your fingers while trying to work with certain radios. I bought a used truck that was formerly a Wal-Mart Semi Tractor. The decal on the dash is literally worn off above the radio and wiper controls. It appears this is where the former drivers where resting their hand while trying to work those controls. I put a piece of velcro (just the fuzzy half) on the dash in the location above the radio. This covered up the wear and made a nice soft spot for me to put my fingers while trying to work the radio. | ||
| [email protected]. |
Oakdale, Il. | I bought a replacement radio from Shoup for my JD9300, it fit nicely and the wiring was able to plug into existing wiring harness. | ||
| nwksmilo |
Colby, KS | The only one you mention I have experience with is REI. I wouldn't buy one again. I put a REI model ST-1000 in a tractor 2 years ago and it is already dying. It functions, but it occasionally changes volume spontaneously when hitting a bump. It actually thinks the knob is turning as the volume indicator on the screen goes down. Also, sometimes when turning the knob up by hand the number goes down, then up. Really poor stuff in my opinion. My go-to radio for farm equipment is this one: http://www.crutchfield.com/p_522JHD1130/Jensen-Heavy-Duty-JHD1130B.html
I've got 3 of them in various machines and they have all been entirely trouble free. Even put one in my farm pickup. | ||
| gh6430 |
| I would suggest a heavy duty Jensen. When we was ordering the last john deere we bought our salesman put it in on the order and said that the John Deere radios now were way over priced and that the Jensen was a lot better radio. I am very pleased with it. It picks up Am/Fm great and it also has a USB port and aux port. It has nice sized buttons and nice screen on it. I like it better than the pioneer in my pickup. My pioneer has the Bluetooth microphone on it and personally I feel like it's overrated. This is the one that we have. I hope this helps. Edited by gh6430 9/4/2014 07:11 (image.jpg) Attachments ---------------- image.jpg (13KB - 283 downloads) | |||
| MEJ |
Manitoba | My Macdon swather came with an REI. Seemed like a very poor quality unit. FM quit after a few years and volume knob was failing by then. | ||
| reedfarmer |
Eastern Arkansas | I have done this many times in deere tractors. First buy one of these for the wiring. It will allow any aftermarket to be plug and play without cutting any wiring harnesses. Every deere tractor I have ever seen uses this plug. http://www.amazon.com/gp/product/B0002BEQKM/ref=oh_details_o00_s00_... I have had one tractor that plugged in but I had to run a separate ground to the radio. Next buy any single din receiver that you would like and install in the slot. Third wire the radio harness to the metra plug, the wires are color coded, it takes about 5 minutes. Then just plug the metra harness into the factory deere harness. This is the radio that I have started using. It has Bluetooth, iphone or android interface and all the other bells and whistles. It doesn't have a CD player but no one uses them anymore and they just get dirty and break anyway. The best thing about this radio is that it is much shallower and lighter than a regular radio, so it allows for a much easier install. http://www.amazon.com/gp/product/B00GS80OQ8/ref=oh_details_o00_s00_... Edited by reedfarmer 9/4/2014 08:14 | ||
| Search this forum Printer friendly version E-mail a link to this thread |
| (Delete cookies) | |
