Search Forums | Classifieds (108) | Skins | Language
7140 magnum cab fan problem
Crystal Creek Farm
Posted 4/10/2014 21:53 (#3808810)
Subject: 7140 magnum cab fan problem
NW Sask, Canada
The cab fan only works on high setting. The first 2 speeds are dead. Replaced the fan switch with same results. I"m wondering if anyone else has had a similar problem, TIA
deerslayer
Posted 4/10/2014 21:58 (#3808823 - in reply to #3808810)
Subject: RE: 7140 magnum cab fan problem
North Dakota
I believe there is a resister by the blower motor that could of failed. Might be able to get to through the cab filter opening if not you'll have to remove cab roof.
swampbuster
Posted 4/10/2014 22:10 (#3808850 - in reply to #3808810)
Marshfield, WI
Its the resister by the motor. Take the cab filter out and you should see it. Our 7120 seemed to go through about every other year. My wrench man got an after market one that's suppose to be better from the case dealer this winter when it went out again
sharecropper
Posted 4/10/2014 22:21 (#3808875 - in reply to #3808810)
southern tip Illinois
Resistor
Crystal Creek Farm
Posted 4/10/2014 22:32 (#3808909 - in reply to #3808875)
NW Sask, Canada
thanks guys, will pick up a resister tomorrow
durallymax
Posted 4/10/2014 23:08 (#3808980 - in reply to #3808875)
Wi
x4  common symptom on any vehicle/tractor etc
smooth
Posted 4/11/2014 04:46 (#3809071 - in reply to #3808980)
Saginaw Valley
You will have to lift the roof to be able to remove the cover over the fan motor to replace the resistor.
I had to replace the resistor on my 92 7140 this winter. Not a bad job, just frustrating not to be able to see the resistor until removal of support (what it is called in the parts book). No access to resistor from inside cab. smooth
pupdaddy12003
Posted 4/11/2014 05:12 (#3809081 - in reply to #3808850)
NW Central Ohio
...I'm guessing you either have a ground problem from the motor or the motor itself is having issues if you're burning up resistors that fast.
ksell
Posted 4/11/2014 06:40 (#3809178 - in reply to #3809071)
West Tennessee
Just changed the one on our 7130 removed filter and it on the right side of blower motor, needed a really short Phillips, or a bit in a 1/4 ratchet
hobby farmer IN
Posted 9/29/2016 12:03 (#5555148 - in reply to #3809178)
Northeast Indiana
