Search Forums | Classifieds (53) | Skins | Language
FM 1000 or EZ Guide 500 with external recievers.........Trimbleman or others
B Leu
Posted 3/25/2014 12:05 (#3775296)
Subject: FM 1000 or EZ Guide 500 with external recievers.........Trimbleman or others
NW Iowa
I have a RTK unlocke 262 that I am no longer using because we upgraded to a 372 for our Accuguide tractor. We have a WAAS EZ Guide 500 or a WAAS FM1000, both running EZ Steer, that we would like to use our 262 with so we can have RTK signal without having to purchase more unlocks. According to Trimble this can only be done with Autopilot and not EZ Steer. I have seen some posts on here stating that it can be done. I would like to know what cables to use and how to configure and setup the monitors for this.
Trimbleguy
Posted 3/25/2014 18:12 (#3775886 - in reply to #3775296)
Subject: RE: FM 1000 or EZ Guide 500 with external recievers.........Trimbleman or others
SEQ, Australia
I don't believe it can be done - it used to work with the 252 and 332 receivers, but I've never tried with a 262.
Trimble Man
Posted 3/26/2014 17:43 (#3778000 - in reply to #3775296)
You can use the RTK262 with Ez-Steer on an Ez-Guide 500, but the FM1000 can only use its internal receiver with Ez-Steer. To do this, ask your dealer for a Power/Data cable, which has a cigarette plug on it for power, and a 9 pin serial connector, that will plug directly into the back of the 500. They will autoconfigure and talk to each other when you power them up.
This can be done with 252 & 262 receivers, but not the newer 372.
If you had an Autopilot system, you could use an external receiver with an FM/1000, but not with an Ez-Guide 500.
B Leu
Posted 3/27/2014 11:10 (#3779625 - in reply to #3778000)
NW Iowa
Will the 372 work with a FM1000 and Autopilot?
Trimble Man
Posted 3/27/2014 21:35 (#3781049 - in reply to #3779625)
Yes, it will work. You will have to connect the 372 directly to the Nav - same wiring setup as the older 252 & FMD Combination.
