New Holland TL 100a won't move?
Hammer7
Posted 3/16/2014 22:22 (#3758390)
Subject: New Holland TL 100a won't move?
South Central, Illinois
Have a TL 100a, was driving down the road and pulled into the drive shifted from 3rd to 2nd and tractor stopped and won't move. When start the tractor the parking light flashes and the caution light but can't get the tractor to move forward or reverse. Have checked the brake fluid and sensor one cap but didn't help. We are all red except this blue and haven't had it all that long so need a little help. Anyone experienced this or have any ideas what would be going on? Thanks for any help
olivetroad
Posted 3/17/2014 05:35 (#3758523 - in reply to #3758390)
Subject: RE: New Holland TL 100a won't move?
Kingdom of Callaway - Fulton, Mo 65251
Does it have the left hand shuttle?
Check your fuses, and try lifting the parking brake one notch up from off.
scott nelsen
Posted 3/17/2014 07:43 (#3758645 - in reply to #3758390)
Leeds, North Dakota
Spencer, any codes? is there a cover on bottom of transmission to inspect and see if dry clutch is actually being actuated? Scott.
Hammer7
Posted 3/17/2014 07:56 (#3758672 - in reply to #3758390)
It does have the left hand shuttle, tried raising the parking break all the way up and releasing but have not tried one notch from off.
I am not sure about any codes.
Allan-Ont
Posted 3/17/2014 12:40 (#3759058 - in reply to #3758390)
Rugby Ontario Canada
I just went through this with a NH TS115 and it ended up being the shuttle lever on the steering column went bad as it had a couple of burnt marks on the circuit board on the shuttle lever . This tractor has the 16x16 semi power shift in it . What transmission does you TL 100A have in it .
CNH Fixer
Posted 3/18/2014 06:46 (#3760502 - in reply to #3758390)
Northwestern MN
Does it flash "CP" or "N" in display? Sounds to me like it could be the seat switch. Check for a broken wire under the seat In the suspension area.
Philko
Posted 3/18/2014 08:21 (#3760657 - in reply to #3758390)
Is the trans locked or will not go into gear?
