AgTalk Home | ||
Cummins M11 coolant line at front of exhaust manifold? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Old Pokey |
There is a small, about 3/8" coolant line at the front of the exhaust manifold. Not connected to the exhaust, but just in front of it. It is attached to some piping that goes to the over flow tank on the truck's fire wall. Its a 95' FLD 112 is that makes a difference. What is the purpose of this coolant line? Is this an aeration elimination line, or?....... It gets warm before any other coolant lines. Thanks. | |||
4WD |
Between Omaha and Des Moines, 7 miles South of I80 | Your describing a coolant vent line going to a coolant expansion tank. Bleeds off some small amounts of air, if there is some in the cooling system. Also, helps to bleed air, during the initial fill of coolant anytime a system was refilled.
(M11%20Engine%20Diagram_exhaust%20side.jpg) Attachments ---------------- M11%20Engine%20Diagram_exhaust%20side.jpg (54KB - 648 downloads) | ||
Old Pokey |
Perfect. Thanks for that. That is just what I needed. I have some air getting into the system. I bought a combustion gas tester and it is not combustion getting into the coolant, but I think it is the air comprssor. The air then over pressurizes my expansion tank. Thanks again. | |||
4WD |
Between Omaha and Des Moines, 7 miles South of I80 | Can you isolate the air compressor water/coolant lines(cap those lines), and just let the air compressor free-wheel (leave off the air compressor's discharge line, so it can't pump any air), THEN see if you still have bubbles in expansion tank, with engine idling?
Also, Some of those older trucks, used an "air style heater control valve" and they can leak "truck system air pressure" into the cooling system at heater hose areas. (M11%20Engine%20Diagram_fuel%20pump%20side.jpg) Attachments ---------------- M11%20Engine%20Diagram_fuel%20pump%20side.jpg (50KB - 615 downloads) | ||
Old Pokey |
Hmmm,.... interesting. I did not know about the heater idea. I will look into that. I did pull a plug on the air tanks so the compressor could not build air, but I did not loop the coolant lines. The compressor does get warm rather quick and it is inconsistent at how it builds pressure. Thanks for the tips. | |||
730diesel |
NE ND | If yours if like mine that line is a small blue hose when it first comes out. From our experience you need to feel that hose during seasonal checkups. On some of our trucks it has become very brittle and just simply cracked and your down. On some trucks it isn't very accessible so I'd change this little hose to keep it soft. Crazy price though, about $80 for a little 10 inch long hose. | ||
(Delete cookies) | |
