Search Forums | Classifieds (93) | Skins | Language
hp. needed to pull a 24 foot great plains turbo till
growmore
Posted 3/2/2014 18:54 (#3728095)
Subject: hp. needed to pull a 24 foot great plains turbo till
Southern Brown Co. Ohio
Thinking about getting one . Have 7130 mfd cih. Is that enough?
hoosierfarmer
Posted 3/2/2014 19:17 (#3728186 - in reply to #3728095)
Subject: RE: hp. needed to pull a 24 foot great plains turbo till
East central Indiana
I would guess no. Around here I think they take around 10 horse per foot of width. Especially to be able to run fast enough.
BlackDirtFarmer
Posted 3/2/2014 19:18 (#3728192 - in reply to #3728095)
North-East Texas
Need at least 10hp per foot, with 12 being better. The faster you can pull it, the better it works.
growmore
Posted 3/2/2014 19:31 (#3728246 - in reply to #3728095)
That's what I thought. Thanks
Corn on corn
Posted 3/2/2014 19:38 (#3728270 - in reply to #3728095)
We have an 18 foot turbo-max.  It is also recommended 10 hp per foot.  We have been pulling it with a JD 4960 (215 hp).  We also have a JD 4850 (210 hp).  You can honestly tell a difference pulling the turbo max with each tractor.  The speed recommended is 7-10 mph.  By having the extra hp we can hit 10mph easily on our river bottom ground.  In our hilly ground we end up running closer to 7.  I would guess it depends on the type of ground you farm (flat or hilly) if you tractor could do it.  I would recommend from my experience to have more than 10 hp per foot.
Corn on corn
mike in sw mn
Posted 3/2/2014 20:21 (#3728466 - in reply to #3728095)
Walnut Grove MN USA
Got a 30 foot Tmax. Mom totally ignored my instructions and plugged it up so I took the mt 855c and TMax and dropped it in the ground at 15mph thinking it would clean right out. I was wrong. It made that tractor snort at that speed. Handles it fine at 8-10 mph.
MO1466
Posted 3/2/2014 20:42 (#3728549 - in reply to #3728095)
Sturgeon MO
Bought a 24' Turbo Till last year. 7150 mfd would barely hack it, CIH 9230 pulls it pretty good but another 50hp wouldn't hurt anything.
mx270
Posted 3/3/2014 14:37 (#3730102 - in reply to #3728095)
NE SD
We ran a 22' with a 7130. Tractor was turned up a little but it worked. I don't think you have to run them at 10 mph. We run ours around 6-7.
