Search Forums | Classifieds (43) | Skins | Language
precision planting on case ih 1250 planter
dantheman
Posted 2/22/2014 10:56 (#3708820)
Subject: precision planting on case ih 1250 planter
We have the 1250 planter with air bags (manually controlled) anyone have one upgraded with a automated down pressure setup from precision ag? what would i need to make this planter auto downpressure, AND more singulation monitoring? My precision guy seems to be struggling getting me this info?!
phonyfarmer
Posted 2/22/2014 11:09 (#3708844 - in reply to #3708820)
Subject: RE: precision planting on case ih 1250 planter
SE IL
Have had everything on 2 1250 16 rows for 2 years-think I'd be finding a new precision guy.
johnny skeptical
Posted 2/22/2014 11:19 (#3708861 - in reply to #3708820)
n.c.iowa
are you running a pro series monitor now?
smalltime25
Posted 2/22/2014 11:29 (#3708884 - in reply to #3708861)
south east mn
We use down pressure from case which is automatic. Every thing else is pp. and I don't think we would run anything else.
dantheman
Posted 2/22/2014 11:57 (#3708926 - in reply to #3708884)
automatic? my nephew says it is manual? we run the '700' monitor
johnny skeptical
Posted 2/22/2014 13:00 (#3708998 - in reply to #3708926)
n.c.iowa
can be either way, depends on how you ordered it. but a manual one can be retrofitted to be automatic.   the ih automatic down pressure doesn't actually read ground contact.   it reads psi and converts it into a down pressure number.
rjp
Posted 2/23/2014 09:16 (#3710504 - in reply to #3708998)
Will acustat do this?
SDnotiller
Posted 2/23/2014 12:04 (#3710809 - in reply to #3710504)
Central South Dakota
We are in the process of looking at options now only for a 5 series case planter. If you have a 700 monitor, you can change the seed tube sensor to the accustat and unlock the monitor and it will do singulation and spacing, but will not control down pressure only tell you what the dp is set at. Am told the accustat unlock is about $1500.
rjp
Posted 2/23/2014 13:33 (#3711001 - in reply to #3710809)
I have a 1245 comin! What will it do ? Thanks
dantheman
Posted 3/2/2014 11:31 (#3726962 - in reply to #3708844)
Are you running case ih seed meters.... will we have trouble running case ih seed meters? or did you go with precision?
dantheman
Posted 3/2/2014 11:34 (#3726966 - in reply to #3708861)
yes we are running 700 pro monitor. We want to keep that , however we want auto downpresssure and singulation and double monitoring .
