Search Forums | Classifieds (107) | Skins | Language
7200 Planter Manual help
mudchief
Posted 2/18/2014 15:04 (#3699448)
Subject: 7200 Planter Manual help
Paola, KS
What manual is needed to show the transmission gear setting/combination for seeding rates on a JD 7200 maxmerge 2 -finger meter planter. I have an operators manual, but it is not listed (only dry fert/insecticide). Thanks.
Posted 2/18/2014 15:10 (#3699453 - in reply to #3699448)
Subject: RE: 7200 Planter Manual help
Mine is in section 70-2 plateless meter seed charts.
OMA51899 issue J0 replaces OM-H-138095-F9 on the cover
Mine is 6 x30" row planter.
Will try and scan my page and post if you need it ?
Use at your own risk after verifying your sprocket combos are correct and that you are in the right range. Mine has a high and low range sprocket setting also.
mudchief
Posted 2/18/2014 15:21 (#3699471 - in reply to #3699453)
Paola, KS
Outstanding. Thank you
