Search Forums | Classifieds (93) | Skins | Language
Installing monitors in Sound guard cab
jdman901
Posted 2/11/2014 08:46 (#3681121)
Subject: Installing monitors in Sound guard cab
Who makes a good bracket to mount monitors on the right side up above SCV levers?
Or just make my own?
jd-tom
Posted 2/11/2014 08:54 (#3681136 - in reply to #3681121)
Subject: RE: Installing monitors in Sound guard cab
SW Minnesota
K&M makes one for Sound-Gard bodies. I have never used one of these so can't tell you if it is a good one or not. There are probably others out there as well. If you are good with a welder, you can make your own also. Just don't do any welding inside the cab!
mcfarm
Posted 2/11/2014 09:07 (#3681172 - in reply to #3681136)
Subject: Re: Installing monitors in Sound guard cab
central Indiana
shoup sells a nice bracket
jdman901
Posted 2/11/2014 09:10 (#3681183 - in reply to #3681121)
Thanks
I have looked at those but can't tell by the pic where it's gonna fit in the cab?
It's a JD 4955 tractor by the way
jd-tom
Posted 2/11/2014 09:15 (#3681199 - in reply to #3681183)
SW Minnesota
The K&M one looks like it would fit where you are wanting a bracket but I'd call them up and ask before ordering.....
AGB
Posted 2/11/2014 09:38 (#3681259 - in reply to #3681121)
Mid-Michigan
In our tractors they mount right on the post. Got them from JD.
jdbob8100
Posted 2/11/2014 10:13 (#3681353 - in reply to #3681259)
ND
In older JD Soundgard cabs, ask JD partsman in the cab parts, they had a plate that fit the curve of the right forward window ahead of you, you can mount a couple of things on it. Bolt on plate from Deere.
Little Duck
Posted 2/11/2014 10:38 (#3681401 - in reply to #3681121)
South East Illinois
I don't have any pictures but I will try and explain what I did. I mad my own, I couldn't see the price in what JD had. I used 2 pieces of 1/4" X 1" flat bar stock. I seprated them enough to put a 1/4" bolt between them. I took the screws from the window lock outs and added a short piece of flat stock. Then welded it to the two piceces of flat so they run between the window post on the right window. Man that sounds confusing. I can try and get some picts.
Edited by Little Duck 2/11/2014 11:21
pointrow
Posted 2/11/2014 11:19 (#3681495 - in reply to #3681121)
Central Il Morton
Just about anything from the side post to the rear post will work. Use self drilling screws and your ready to mount. Height of bar is important for easy window opening.
good
luck
pointrow
Little Duck
Posted 2/11/2014 11:29 (#3681518 - in reply to #3681495)
South East Illinois
picts.
Edited by Little Duck 2/11/2014 11:30
(DSC04095 (Small).JPG)
(DSC04096 (Small).JPG)
(DSC04097 (Small).JPG)
(DSC04098 (Small).JPG)
Attachments DSC04095 (Small).JPG (61KB - 550 downloads)
Attachments DSC04096 (Small).JPG (59KB - 570 downloads)
Attachments DSC04097 (Small).JPG (75KB - 728 downloads)
Attachments DSC04098 (Small).JPG (60KB - 603 downloads)
4WD
Posted 2/11/2014 13:02 (#3681748 - in reply to #3681136)
Between Omaha and Des Moines, 7 miles South of I80
Here's K and M bracket, But I don't really see how it attaches. ??? (Anyone have one and a picture, inside the cab.)
http://www.kandmmanufacturing.com/p-105050-jd-sound-guard-monitor-bracket.aspx
(3189_01_K and M Soundgard bracket.jpg)
Attachments 3189_01_K and M Soundgard bracket.jpg (47KB - 783 downloads)
4WD
Posted 2/11/2014 13:13 (#3681778 - in reply to #3681121)
Dad has a 3960 forage chopper and JD has a bracket, that fit under the "black metal lip", by the window; the lip that your cab foam fit underneath. It is #9 in this photo; it can slide anywhere along that black lip, and get snugged by those #10 screws.
It is too expensive from JD, for what it is, the last time I checked the price, but Dad has one on each side = 1 for electric forage chopper controls(right side), then one on the left side, has another clamped to that black lip, and it holds the rope, for the latch mechanism, for the wagon tongue "quick hitch/release".
Part # RE39122 bracket
2 of #R52938 screws
Just thought I would mention it as an option.
Edited by 4WD 2/11/2014 13:15
(EP7499_________UN01JAN94_3960 chopper bracket _9_in photo.gif)
Attachments EP7499_________UN01JAN94_3960 chopper bracket _9_in photo.gif (33KB - 566 downloads)
jwsrules
Posted 2/11/2014 13:37 (#3681844 - in reply to #3681121)
This is what i did.
(2011-08-25_16-33-18_882.jpg)
Attachments 2011-08-25_16-33-18_882.jpg (50KB - 588 downloads)
DeereGuy 149
Posted 2/11/2014 15:51 (#3682111 - in reply to #3681121)
Maynard, mn
Here are some pictures of K&M's monitor bracket.
(back mount.jpg)
(front mount.jpg)
(IMG_8349.jpg)
Attachments back mount.jpg (92KB - 571 downloads)
Attachments front mount.jpg (95KB - 631 downloads)
Attachments IMG_8349.jpg (46KB - 630 downloads)
jdbob8100
Posted 2/11/2014 16:29 (#3682183 - in reply to #3681748)
ND
That bracket is for a 8100 thro 8400 tractor-unless that's what jdman has for a tractor. I thought he had the older soundgard cab like in a 4650
jdman901
Posted 2/11/2014 18:01 (#3682414 - in reply to #3681121)
Thanks for input I like the k&m mount.
How much room is there between window glass and mount ??
4WD
Posted 2/11/2014 18:50 (#3682530 - in reply to #3682111)
Thank you, very much for the photos, that really helps.
4WD
Posted 2/11/2014 19:11 (#3682590 - in reply to #3681518)
Last year, I tried to remove those Phillips head screws, for window latches = didn't want to loosen. (was going to built something, in-between those screws, too)
 I even had an impact screwdriver and hitting it with a 2 lb hammer, and one still wouldn't loosen (=broke the phillips bit), I gave up on that idea, and added a SMV "female" bracket to my drink holder/ash tray. Put sprayer control, onto the "male" SMV bracket, and added another "leg" to stabilize it, against drink holder.
Note: Now, that I see the K&M bracket, it wouldn't work either, with the JD forage chopper controls, in right, rear corner.
DeereGuy 149
Posted 2/12/2014 07:15 (#3683705 - in reply to #3682414)
Maynard, mn
There is 2 inches between the window and the edge of the bracket. It could be moved out since the holes have to be drilled. I would guess you could get three or four inches if you needed to.
