Howse cutter?
Justin ArkMo
Posted 2/8/2014 10:59 (#3673132)
Subject: Howse cutter?
The Delta
Looking for 3pt 10' cutter to mow around farms, are these any good? Will be behind a 7215r . I know they arent top quality but I would be happy to get 3 years out of it.
Red/Green
Posted 2/8/2014 11:02 (#3673143 - in reply to #3673132)
Subject: Re: Howse cutter?
Elizabethtown,KY
I owned my first and last one several years ago, nothing but junk!
farmerboy1973
Posted 2/8/2014 11:37 (#3673214 - in reply to #3673132)
Subject: RE: Howse cutter?
NE Arkansas SE Missouri
Junk!!!!
IFarmtoo
Posted 2/8/2014 11:52 (#3673243 - in reply to #3673132)
Eastern Iowa
If you are going to use a tractor in the upper HP range you might want to spend a little more and get one with a heavyer gear box. Land Pride mowers are good quality if you have a dealer in your area.
5288
Posted 2/8/2014 12:42 (#3673356 - in reply to #3673243)
S.E. South Dakota
There a fine lawn mower.
Detroit
Posted 2/8/2014 12:45 (#3673362 - in reply to #3673132)
Crawfordsville, Arkansas
We bought a nice older 7' Bush Hog last year at a sale in Luxora. $600 I believe. It's a late 80's or early 90's model when they actually used real steel in a mower. Have ran it on a 200+ horse tractor and it did fine.
There's a sale coming up in a few weeks close by me. I'm sure there will be some mowers there.
Justin ArkMo
Posted 2/8/2014 13:09 (#3673419 - in reply to #3673132)
The Delta
Whose got the sale? I may come down and watch.
JJS
Posted 2/8/2014 16:20 (#3673777 - in reply to #3673132)
Southern Lower Michigan
Bought one back in the early 80s paid just over $1000 for it Brand New . Just sold it last year for $600.
early on I had to replace both blade carriers, and repair the 3pt lift, and one U joint in the cross drive. other than blades it ran fairly well for the rest of its life here.
It was used mainly for roadsides, lanes, and on occasion , weedy wheat stubble , and light brush (usually not more than 2"). Never had any trouble with the gear boxes.
The newer ones have a heavier built blade carriers, and 3pt lift . For me ,it was a good unit for the money, and my uses
Their original blades were only 3/8 thick, and wouldn't last very long. I was able to replace them with 1/2 thick blades for a Woods mower.
Those blades lasted a lot better.
Joe
Detroit
Posted 2/8/2014 16:33 (#3673803 - in reply to #3673419)
Justin ArkMo - 2/8/2014 12:09
Dewitt.
Bring a trailer and take your floater tires and flip plow home.
Edited by Detroit 2/8/2014 16:34
Justin ArkMo
Posted 2/8/2014 17:17 (#3673916 - in reply to #3673132)
The Delta
Ahh your right, I need to come look at that plow, how do you like your switch plow? I think I can really put a number on pigweeds once there 10" under.
Detroit
Posted 2/8/2014 18:29 (#3674064 - in reply to #3673916)
Justin ArkMo - 2/8/2014 16:17
Well it's a non NAT approved tillage tool but it sure does us a good job.
