Search Forums | Classifieds (58) | Skins | Language
Cat 35 questions
iadirt
Posted 1/23/2014 05:47 (#3627772)
Subject: Cat 35 questions
These machines seem to be priced lower than a comparable mfwd tractor. Are there any design issues or concerns? Likes/dislikes?
How difficult to get from 60" to 120"?
Anyone have a front blade on one for shaping waterways and other dirt work?
rlbsek
Posted 1/23/2014 06:18 (#3627791 - in reply to #3627772)
Subject: Re: Cat 35 questions
Chanute, KS.
Best way to tear one up is put a blade on it, they are not a bulldozer. To get to 120" you really need one that was wide stance to start with. But used as you would a mfd they are solid.
KORN *
Posted 1/23/2014 09:45 (#3628343 - in reply to #3627772)
Subject: RE: Cat 35 questions
Ottawa . Ca
iadirt - 1/23/2014 05:47 These machines seem to be priced lower than a comparable mfwd tractor. Are there any design issues or concerns? Likes/dislikes? How difficult to get from 60" to 120"? Anyone have a front blade on one for shaping waterways and other dirt work?
I believe it. I have had a 35 for some time now. Has treated us well. However when it comes time to sell it, there are really no buyers for a track tractor, here anyway, damn near couldn't give 'em away. I tried to sell it.
Edited by KORN * 1/23/2014 10:28
(DSC02897.jpg)
Attachments DSC02897.jpg (67KB - 324 downloads)
22 inch row
Posted 1/23/2014 10:07 (#3628412 - in reply to #3627772)
south central Minnesota
You have to buy spacers on the old ones to change stance. If you want 120" you better look for a wide stance machine. I have had one for 10+ 1995 model planter,sprayer,stalk chopper, scraper tractor,grain cart only bought a starter and batteries. The ride is 100% dependent on the tracks, good tracks= good ride. The ford/genesis transmission in my opinion is still one of the simplest trans to run I almost never have to push in clutch-inch pedal. The 35 will be kind of guttless for tillage they weigh 31,000lbs and are only 180 hp if you want a tillage tractor get 45 or 55. I think they are the best value in the used market.
iadirt
Posted 1/23/2014 12:31 (#3628817 - in reply to #3628343)
What do you want for it?
150pilot
Posted 1/24/2014 10:24 (#3631495 - in reply to #3628412)
New London, Wisconsin
Is the 31,000 with additional weight? That is heavier than I thought. TractorData was my source, and perhaps its wrong.
Tractors:
-Farm Tractors
-Lawn Tractors
-Compare tractors
-Brand search:
Classifieds
-Tractors for sale
-Place free ad
Sections:
-Articles/News
-Tractor Shows
-Store
-Contact
Cat Caterpillar Challenger 35 Tractor Er ...
$12.95 4h 56m
1994 CATERPILLAR TRACTOR CHALLENGER 35 4 ...
$7.00 23h 27m
1999 CATERPILLAR TRACTOR CHALLENGER 35 4 ...
$7.00 23h 29m
View all disclaimer
Antique Tractor Bible
Challenger 35
1995 - 1998
Agricultural Crawler tractor
Larger: Challenger 45
Overview
Engine
Transmission
Dimensions
Photos
Production:
Manufacturer: Caterpillar
Original price (USD): $118,875 (1998)
Challenger 35 Engine:
Caterpillar 6.6L 6-cyl diesel
full engine details ...
Capacity:
Fuel: 85 gal [321.7 L]
Hydraulic system: 32 gal [121.1 L]
3-Point Hitch:
Rear Type: 3/2
Rear lift: 12500 lbs [5670 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPMs: 1000
Dimensions & Tires:
Wheelbase: 86 inches [218 cm]
Weight: 22,262 lbs [10098 kg]
Front tire: tracks
Rear tire: tracks
full dimensions and tires ...
35 Serial Numbers:
- Serial numbers unknown -
Challenger 35 Power:
Engine: 210 hp [156.6 kW]
Drawbar (claimed): 150 hp [111.9 kW]
PTO (claimed): 175 hp [130.5 kW]
Mechanical:
Chassis: crawler
Cab: cab
Hydraulics:
Type: closed center
Capacity: 32 gal [121.1 L]
Valves: 3
Pump flow: 31 gpm [117.3 lpm]
Electrical:
Ground: negative
Battery:
Volts: 12
Page information:
Last update: January 11, 2013
Copyright: Copyright 2013 TractorData LLC
Contact: Peter@TractorData.com
Edited by 150pilot 1/24/2014 10:25
KORN *
Posted 1/24/2014 19:07 (#3632590 - in reply to #3628817)
Ottawa . Ca
iadirt - 1/23/2014 12:31 What do you want for it?
My email is good in my profile....
(DSC02895.jpg)
Attachments DSC02895.jpg (62KB - 320 downloads)
Busted Knuckles
Posted 1/25/2014 11:34 (#3634164 - in reply to #3631495)
Southeast Minnesota
Pretty sure that is with weight added.
