John Deere 9100
MEM
Posted 11/25/2013 09:17 (#3468264)
Subject: John Deere 9100
I am Looking at getting one of these tractors to pull a 30’ 1890 air seeder with a 340 bu tow behind cart.  Are these good tractors? Will it have enough power and hydraulic capacity?  Do these tractors have the same water pump issues that the larger engines do?
JRthefarmer
Posted 11/25/2013 12:53 (#3468606 - in reply to #3468264)
Subject: Re: John Deere 9100
SESD
I run an 1860 w/ 195bu tow behind. I wouldn't want a smaller tractor on it. A full cart makes a lot of difference. If you are going to run on flat ground should be fine. The problem is the transmission. When you get in a hard pull, like up a hill, it's very hard to shift. I've had to stop and back down the hill and shift to a lower gear more than once. No trouble with my tractor and it's at about 3k hrs. Hydraulic capacity is sufficient, but does take power to run 2 scv's in constant all the time. In an uphill pull, I will also take the row units out of constant for a short time to make it to the top. Overall, they are nice tractors.
retento
Posted 11/25/2013 13:27 (#3468670 - in reply to #3468606)
Eastern North Carolina
Didn't realize they used the 8.1 engine in the 9100... 260 engine hp, 214 pto...
8430Aaron
Posted 11/25/2013 13:46 (#3468693 - in reply to #3468264)
Dennison, IL
Not exactly the same problems as the larger engines ( won't drop bearings in engine) but will dump water and metal shavings into the oil. We've had more problems with these than the larger engines. Junk
Detroit
Posted 11/25/2013 16:37 (#3468941 - in reply to #3468264)
Crawfordsville, Arkansas
We had a 8570 then traded for a 9100. Went downhill on that trade. Just about the most gutless tractor I've been in.
