Search Forums | Classifieds (64) | Skins | Language
John Deere 7200r vs 7930 vs 8130
farmfresh7800
Posted 11/24/2013 20:45 (#3467325)
Subject: John Deere 7200r vs 7930 vs 8130
west of Omaha NE
Looking at trading in 7800jd 2wd. Would use it on a 90ft pull type sprayer, 700bu grain cart some light tillage have an 8285r for heavy tillage. Was looking at 7930 and 7200r both mfwd this past weekend. The 7200 look like they have 4 transmission IVT, power quad 16speed, auto quad 20sp, and command quad plus. What do I need I would a assume the IVT would cost the most but what about the other pros or con? of each. Or should I look for a small 8XXX tractor? do they turn short
garvo
Posted 11/24/2013 20:46 (#3467332 - in reply to #3467325)
Subject: Re: John Deere 7200r vs 7930 vs 8130
western iowa,by Denison
maybe buy a low hour 8100 -less trouble?
ricksitzmann
Posted 11/24/2013 20:47 (#3467335 - in reply to #3467325)
Iowa
Love our 7930, heard bad things about the 7rs, 8x30s are good tractors.... Garvo seems to be onto something with the 8100, especially for the money
j Feces
Posted 11/24/2013 20:48 (#3467336 - in reply to #3467325)
SW Ont
If you are set on 60 in centers for 30 in rows the 7R is terrible for turning. I have 7215R and had it set in for 60 but moved the wheels out. Much better now. Good luck.
Big Ben
Posted 11/24/2013 21:06 (#3467408 - in reply to #3467325)
Subject: RE: John Deere 7200r vs 7930 vs 8130
Columbia Basin, Ephrata, WA
I'd go with the 8130 of those three choices. I have not regretted for a minute that I bought an 8130 over a 7930, but I have regretted a few times that I didn't get an 8120 and have a tractor with less emissions gear. Deere is really screwing the pooch when it comes to their approach to emissions compliance, IMO.
Edited by Ben in the Basin 11/24/2013 21:07
Jd7730
Posted 11/24/2013 21:09 (#3467418 - in reply to #3467325)
SE MN
I think definitely go with the 8130. I don't know the specs, but I think it will turn as short as a 7030 or 7r, maybe shorter. The 8000 is a bigger heavier tractor that handles like a smaller one. The 8130 will have a 9.0 liter engine compared to the 6.8 liter in the 7930. If you don't want the IVT you can get the 16 speed power shift which is so much nicer to drive than the auto quad transmission and the command-arm controls are standard on the 8000, on the 7030 and (I'm maybe with the 7r too) it's only available with the IVT transmission.
copper105
Posted 11/24/2013 21:11 (#3467427 - in reply to #3467325)
NE Illinois
IDK where you are but know where there is a low hour 8120 with Ils for sale near chicago il
Justin ArkMo
Posted 11/24/2013 22:23 (#3467612 - in reply to #3467325)
The Delta
Theyre are 2 types of thoughts here, warranty and non warranty. I hated the first 8400 I owned in 95, bugs got worked out and it was a horse. Biggest issue with an IVT 7R deere recognizes and splits the machine.
Chris 924
Posted 11/24/2013 22:37 (#3467651 - in reply to #3467325)
Nova Scotia
Go 7R with command quad , transmission shift just like 8130 16 speed does , just keep pushing the one knob ahead , everything is on command arm , nice set up. we had few bugs with ours at first but have gotten them sorted out , would agree on passing on there IVT
MSR
Posted 11/25/2013 04:15 (#3467797 - in reply to #3467651)
Been in your shoes and we have a 7215R, 8130, 8230 etc. We have really liked the 8's and we have had good luck with our 7215, some have not ours was one deere had to split and redo the tranny bearings on it but its been great since then. One thing is the weight on these tractors your 7r and 8's will weigh in at 23-25k depending on weights and the 7930 is in the 17-18k range for us we are going the lighter route and have a 6210R and possibly a 7830 on the way. Out of all of them if I had to have one it would be the 7215R mainly for the cab layout and its just a nice tractor to run.
wbstofer
Posted 11/25/2013 05:42 (#3467830 - in reply to #3467427)
North Central IN
Please tell us (and by us, I mean me!). Contact info good....
AGB
Posted 11/25/2013 07:07 (#3467935 - in reply to #3467325)
Mid-Michigan
Been doing quite a bit of shopping and price checking on tractors. The Ivt tranny on a john Deere is about an $8000 option (just for what its worth to you).
cutchall5
Posted 11/25/2013 11:18 (#3468468 - in reply to #3467332)
Jonesville, Mi
garvo - 11/24/2013 20:46
+1 we really like our 2wd one and it is a cheap tractor to maintain.
farmfresh7800
Posted 11/25/2013 17:31 (#3469020 - in reply to #3467427)
west of Omaha NE
Hi copper 15.I will be heading to Chicago this weekend for thanksgiving. if you have any more info on the 8120
thanks
email is good
