| AgTalk Home | ||
2410 John Deere ChiselJump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
| Forums List -> Machinery Talk | Message format |
| kodiak2 |
SE SD | Just curious how big of a 2410 chisel will a 9400 4wd pull. What size do you have and what do you pull it with? Thanks | ||
| collegeboy |
Slicker than a Yes album. | Depends on the shanks and the number of them. Used to pull a 32' 22 shank 680 with the tru depth shanks and it was all a 9400/9520T wanted. That was also pulling a 1500 gal NH3 tank behind it. Now we have a 25 knife 62' 2410 pulling doubles and it's a load for the 9560RT. (NH3Wide.jpg) Attachments ---------------- NH3Wide.jpg (48KB - 470 downloads) | ||
| Mbmaring |
North west MN | We have a 44' 2410 and pull with a 9520 pulls it just fine could handle a bigger one | ||
| Duane in ND |
North central North Dakota | How deep, how fast and how good of a welder are you? Edited by Duane in ND 11/20/2013 07:04 (IMG_0362b.jpg) (IMG_0360b.JPG) Attachments ---------------- IMG_0362b.jpg (41KB - 489 downloads) IMG_0360b.JPG (81KB - 511 downloads) | ||
| albertson_08 |
SW Minnesota | We have a 17'5 foot with 12" spacing trudepth we pull it with a 9200 | ||
| minn gopher |
Pine City, MN | Mbmaring - 11/20/2013 05:40 . Wow. Our 33 ft is all our 9520 will handle. 16" spacing. Last couple dry years we took end 2 shanks off. Depends how deep you go I guess.We have a 44' 2410 and pull with a 9520 pulls it just fine could handle a bigger one | ||
| Mbmaring |
North west MN | Is yours a wheel tractor or track mine is a T we can pull that 44' 5 to 6 inches deep at 6 to 7 MPH | ||
| skitts |
SE Minnestoa | Did you have to put the second hitch on yourself? How did you do it? | ||
| jath1001 |
Central MN | I believe ours is a 33 foot. has 33 shanks on 12 inch spacing. I pulled it with a 9410R tilling up rye and wheat ground (lighter dirt). Went about 7 inches deep and it pulled a bit hard. Tractor power hopped. If I had the tire pressure set better and weighted right it could have pulled it better but its still a lot for that tractor. We usually pull it with our 9560 RT in soybean ground and it handles it just fine. 10 inches deep. Edited by jath1001 11/20/2013 08:52 (20130818_100708.jpg) (9560 plow 1.jpg) (9560 plow 2.jpg) Attachments ---------------- 20130818_100708.jpg (44KB - 559 downloads) 9560 plow 1.jpg (71KB - 511 downloads) 9560 plow 2.jpg (48KB - 522 downloads) | ||
| Gerard |
Woodham, Ontario | Do you push silage with the 9560RT? | ||
| jath1001 |
Central MN | Yes we do. 16 foot grouser blade. Its really heavy on this tractors front so we built a weight bar and hung 18 suitcase weights on the back to help compensate it. It helped keep it more flat on the pile otherwise the grill was always leaning down towards the pile. (9560 silage 1.jpg) (9560 silage 2.jpg) (9560 silage 3.jpg) Attachments ---------------- 9560 silage 1.jpg (11KB - 492 downloads) 9560 silage 2.jpg (26KB - 498 downloads) 9560 silage 3.jpg (63KB - 473 downloads) | ||
| minn gopher |
Pine City, MN | Wheel 800's. loaded with weight. We go deeper. 8 or so. | ||
| 69roadrunner |
| Wow, I thought the only good design was the frame. The shanks and assembly are junk. | |||
| farmnmn |
Walnut Grove, MN. | 9420 with a 38 footer i wouldnt get one any bigger for this size of tractor i go around 6 mph. | ||
| collegeboy |
Slicker than a Yes album. | We get them from Ag Systems in Hutchinson, MN. They are a bolt on design, have a third one in the middle that isn't in the pic yet. That one has bars tied to the frame toward the front as there is no boxing to help hold things together in the middle. (boxed around the main lift wheels on either side, so that's not a problem.) (IMG_4130.jpg) (IMG_4131.jpg) Attachments ---------------- IMG_4130.jpg (70KB - 495 downloads) IMG_4131.jpg (75KB - 485 downloads) | ||
| Search this forum Printer friendly version E-mail a link to this thread |
| (Delete cookies) | |
