![](http://i1304.photobucket.com/albums/s534/MCatSHF/Mini%20Me/IMG_3004copy_zps207b8fe8.jpg) Sandy Hook, MB | Hello Golfnut
In reply to your thread. I've used a few of those rollers. I made 5 - 12' sections of adjustable height rollers for use on my sawmill to move the lumber from the takeaway belt to the edger & beyond. On those the rollers are spaced 2' apart I think. I machined a flat spot on the shafts so that they sat on the frame better. I also made 2 single adjustable stands that I use in the shop. I've used them for my band saw, drill press & hydraulic press. I just used 0.100 wall 1" & 1 1/4" tubing for it to telescope for height adjustment. The bases are the ends that I had cut out of some water tanks from another project.
![](http://i1304.photobucket.com/albums/s534/MCatSHF/Roller%20Stands/IMG_5756_zps4e081eee.jpg)
Adjustable single roller stand.
![](http://i1304.photobucket.com/albums/s534/MCatSHF/Roller%20Stands/IMG_5757_zps5b42adca.jpg)
After welding nut, drilled & tapped through tubing for a little more thread.
![](http://i1304.photobucket.com/albums/s534/MCatSHF/Roller%20Stands/IMG_5759_zps15433c0e.jpg)
Base is from a water tank.
![](http://i1304.photobucket.com/albums/s534/MCatSHF/Roller%20Stands/IMG_5760_zps8192e04b.jpg)
Roller.
![](http://i1304.photobucket.com/albums/s534/MCatSHF/Roller%20Stands/IMG_5761_zps8273cdf2.jpg)
How I mounted the roller. Didn't have mill when I made these. On the stands for my sawmill, I machined a flat spot on the shafts so that the roller shaft would sit nice on the frames.
That's a 480 lb. piece of 1" x 12" x 12' flat.
