Search Forums | Classifieds (73) | Skins | Language
LOST OIL PRESSURE! CIH1660 with 8.3L Cummins
redhunter
Posted 10/25/2013 19:20 (#3404651)
Subject: LOST OIL PRESSURE! CIH1660 with 8.3L Cummins
Owensville, MO
Finished one farm of beans today and was moving to another when alarm goes off while on the road. Look over and oil pressure gauge is at zero. Got it off the road and shut it down. Maybe 15 seconds after alarm. My first thought was sending unit so I pulled it off and made some calls to locate a new one. Thought maybe I should check to be sure that is the problem so I had brother watch the sending unit hole while I started the engine. Started the engine and no oil. That's not good. Decided to try one more thing so I pulled the pressure line off the turbo. Started engine and again no oil. Oil level is full so now I'm thinking oil pump shot crap on me. Dealer says he thinks it's probably the suction tube broke off.
So now I'm looking for ideas on what it might be, also on what needs to be done to fix it. Do I need to pull the motor? Sure looks like it if I need the pan off. Could a keyway have sheered on the pump drive or something? I've been in lots of IH motors but not a cummins. If you guys can somewhat walk me through a few things I can get it fixed. If the motor has to be pulled is there any tricks I need to know about or just tear into it??
Also it is setting on the side of a gravel road about 3.5 miles from the farm. Would sure like to get it back to the shop if it needs major surgery. Any good ideas on how to maybe tow it back home other than a $1000 wrecker bill??
Thanks guys
Joe
Badger
Posted 10/25/2013 19:29 (#3404662 - in reply to #3404651)
Subject: Re: LOST OIL PRESSURE! CIH1660 with 8.3L Cummins
Huntley Montana
Pull the sleeves on the drive shafts, 2 chains With 2 pipes to keep it back from the tractor, or 2 tractors 1 front, 1 rear, & have someone steer it as you tow it home as once you pull the sleeves you have NO BRAKES.
lilmule
Posted 10/25/2013 19:31 (#3404667 - in reply to #3404651)
arthur , ontario
over fill it with oil so the pump is submerged! if it doesn't make pressure then? well you definitely have a pump problem? just an idea,good luck?
croptecsolutions
Posted 10/25/2013 19:47 (#3404708 - in reply to #3404667)
ok
There bad about cracking the pickup tube on trucks....not sure on Ag..
ihsteve
Posted 10/25/2013 20:03 (#3404732 - in reply to #3404651)
Subject: RE: LOST OIL PRESSURE! CIH1660 with 8.3L Cummins
Gear loose on shaft likely....see this thread on RedPower.....I know that was the issue with this machine discussed.
http://www.redpowermagazine.com/forums/index.php?showtopic=60510
striker782
Posted 10/25/2013 20:08 (#3404743 - in reply to #3404651)
Grand Island, Nebraska
Oil pump is located behind front cover.
scottpf
Posted 10/25/2013 20:14 (#3404756 - in reply to #3404743)
Probably the gears on the oil pump went bad. Just pull the front tin cover off and then 4 bolts and replace the pump. Hopefully the rest of the engine will be fine.
redhunter
Posted 10/25/2013 20:30 (#3404786 - in reply to #3404651)
Owensville, MO
If I overfill it with oil, how much? how high up is the pump?
Thanks
Joe
kirk
Posted 10/25/2013 20:32 (#3404788 - in reply to #3404651)
Dills, FL
15 seconds did not hurt it. good luck. I have come to realize farming is a patience exercise>
EH1660
Posted 10/25/2013 20:37 (#3404798 - in reply to #3404788)
How many hours on it.
Small-timer
Posted 10/25/2013 20:38 (#3404802 - in reply to #3404651)
SW WI
Take a pipe, weld a hitch on each end. Then get hyd hoses made and hook them to the steer cylinder on the combine. Run them to the outlet on the tractor and pull er home.
redhunter
Posted 10/25/2013 20:49 (#3404831 - in reply to #3404798)
Owensville, MO
3500
redhunter
Posted 10/25/2013 20:51 (#3404834 - in reply to #3404732)
Owensville, MO
How big of a job is it to get that front cover off? Dampner pulley has to come off right? Do I need to pull the radiator?
Joe
boog
Posted 10/25/2013 20:56 (#3404849 - in reply to #3404651)
Had that happen several years ago to a 1660 w Cummins engine. Going down the road the engine locked up, no warning, nothing. Oil pump had sheared it' drive shaft. Had to have a new short block put in it. Hope you have better luck.
rambo
Posted 10/25/2013 23:07 (#3405118 - in reply to #3404802)
Remsen, Iowa
Did the same thing more than once.
IL cow man
Posted 10/26/2013 04:53 (#3405263 - in reply to #3404849)
Buffalo IL
Had the same thing happen as boog. Sheared shaft and fixed it then overhauled it next year because missed some filings and they went thru motor.
Larry NCKS
Posted 10/26/2013 06:28 (#3405325 - in reply to #3404662)
Washington, Kansas & Lincoln, Nebraska
For 3.5 miles, I'd just put the range transmission in neutral. Should still have some manual braking capabilities then.
grtown
Posted 10/26/2013 15:01 (#3405908 - in reply to #3404651)
Central Ontario
Had to much 8.3 oil pump experience lately.The pump is above the centre line of the crank,the suck tube bolts to the block at the level of the oil pan.The pump is removable on a 2366 by taking off the fan ,pulleys ,balancer and then the gear cover.Had to remove engine to work on suck tube.Make sure you install the suck tube gasket the right way up, enough said.Had a challenge sealing up the gear cover,I would buy the recomended sealer.If I had the engine out I would get someone who should know to look at the bearings.
