Search Forums | Classifieds (20) | Skins | Language
Massey Ferguson 390 as a loader tractor?
9520Deere
Posted 2/6/2008 12:46 (#302651)
Subject: Massey Ferguson 390 as a loader tractor?
Alberta Canada
I am in the market for a smaller haying tractor to keep some hrs off my 6410 and 4440. I am wanting to rake and pick round bales with it. I found a 1996 Massey Ferguson 390 (70hp) with fwa with out a loader. My question is would this tractor stand up to some loader work? Just loading round bales (1000lbs-1600lbs) in the field, and possibly stacking in the yard. Anyone have a tractor this size with a loader? How do you like it or do you wish you looked for something bigger?
deeredriver
Posted 2/6/2008 19:19 (#302957 - in reply to #302651)
Subject: Re: Massey Ferguson 390 as a loader tractor?
Alma NE
what tranny is it is it the 12-12 with the shutle on the left of the steering wheel
that prob used to be the most popular loader tractor back home when i was there well a 390T they were 90hp
9520Deere
Posted 2/6/2008 22:16 (#303149 - in reply to #302651)
Subject: RE: Massey Ferguson 390 as a loader tractor?
Alberta Canada
No I dont think its the 12-12 I think its just the standard. They are asking $13500, I think thats about 4k too much. How do you like the 390T for loader work? Is it alittle light or will it run beside an equivilant JD or CIH?
390
onion farmer
Posted 2/6/2008 22:55 (#303195 - in reply to #302651)
southeast Washington
The 390 were good little tractors .I found one for a friend of mine and he has had no trouble at all .It has a cab and is a eight speed we put a loader on it and he moves hay and any other jobs that come along.
9520Deere
Posted 2/6/2008 23:00 (#303206 - in reply to #302651)
Alberta Canada
How does he like it for moving hay? Does he move the 6x5 bales?
deeredriver
Posted 2/6/2008 23:10 (#303221 - in reply to #303206)
Alma NE
its ok they used move a lot of silage round bales back home with them no real trouble at all
the clutches would wear out on them around 3000 hrs but what can you expect really for a small tractor anda lot of gear changes
the one i used to drive never hada loader on it was a 390t put 3000 hrs on it the first year that was our bigest tractor on the farm it got all real work it pulled a 4 furrow rollover plough no trouble didnt quiet have the weight for the plow so we had a platform on the front that a shuttle full of water would sit on that kept the front down
good simple plain tractors
pudding
Posted 2/7/2008 03:24 (#303324 - in reply to #302651)
Somewhereville, Earth
if it has a left hand reverser on the coloumn its a 12x12
if it has a big lever on the right of the seat, the gear lever, that you push sideways for range change its a 18x6
some of the early ones were 12x4, with 3 levers on the floor or 8x8
they are a tried and tested utility,
keep the grease up to the front axle pivot, all loader tractors fail there adventually
if it leaks round the PTO seal, that is common, not a hard fix
if its a 18x6 they sometimes break the spring in the tranny for the range shift, half hour job if you double jointed , 8 hours the hard way
good tractors, will do what ya want well
perkins motor is ok, front axle is ZF ? ain't it
onion farmer
Posted 2/7/2008 09:45 (#303473 - in reply to #303206)
AS far as mowing hay its fine but this tractor is a (plain jane) and has a live pto and a dual clutch.And yes he does pick up 6x5 bales.
