Search Forums | Classifieds (43) | Skins | Language
608c corn head oil
Maizeing
Posted 9/19/2013 15:37 (#3337256)
Subject: 608c corn head oil
Ontario's middle east
Pulled the plug and it looks a little creamy. The heads never sat outside, condensation maybe ? Or is this what the Deere oil looks like. It suppose to have 80w90 in it, but I don't see a plug to drain it. Why a grease fitting on top with oil in it? TIA
KTA
Posted 9/19/2013 16:07 (#3337288 - in reply to #3337256)
Subject: Re: 608c corn head oil
What year head? Pretty sure with a fitting, it will require cornhead grease not gear oil.
Fred
Posted 9/19/2013 16:31 (#3337329 - in reply to #3337256)
south east SD
Mine has oil dip stick with a O ring that screws in like the older Deere heads, square in set. Mine is 80-90 and when I checked mine last week they were full and looked like oil. Mine is a 2012 model. What year is yours?
PrecisionTy
Posted 9/19/2013 16:31 (#3337330 - in reply to #3337256)
Eastern Shore
If it has a grease fitting up top, it takes cornhead grease.
Maizeing
Posted 9/19/2013 17:12 (#3337400 - in reply to #3337329)
I think this is 2011 . It has a Allen key plug that is a dipstick. Dealer said by serial number should be gear lube. Doesn't look like gear lube or corn head grease. More like .....ox snot....
coconutfarmer
Posted 9/19/2013 21:22 (#3338012 - in reply to #3337256)
Eastern Ontario
We just took delivery of a 2013 608c and I wondered the same thing. Manual says its 80-90 ( Deere brand of course)
Maizeing
Posted 9/20/2013 00:48 (#3338363 - in reply to #3338012)
Good to see you on here. Haven't heard from for a while. Hope all is well.
spudbubba
Posted 9/20/2013 07:27 (#3338576 - in reply to #3337256)
MY 12 and 13 heads use 80-90, all the older ones use corn head grease.
