| AgTalk Home | ||
Case 930, 830, 730 tractors?Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
| Forums List -> Machinery Talk | Message format |
| granto |
18c ditch system, winthrop Mn | Always liked the looks of them. Never drove one. When were they made and how did they stack up? | ||
| Herbie56 |
Coles County, Illinois | I put a lot of hours on a couple 830 gases (64 & 68). They were about 10 years behind the times when compared to JD, IH or Oliver. Low Rpm engines that weren't well balanced, poor belt driven power steering. You could lug the motors down to 1100 rpm though. | ||
| Rusty6 |
S.E. Sask. | <p>30 series were about my favourite series Case. Engines were pretty much trouble free for year round use. Dry disk brakes were adequate. Hydraulics simple and reliable although they had their own unique type coupler that was not compatible with any others. The power steering pump could be a little trouble some at times although I dont' recall a lot of problems on my late model 930. I'd buy it back in a heartbeat if given the chance. This old 730 diesel has been on the farm for nearly 50 years with no major problems and uncounted hours of use. http://www.youtube.com/watch?v=_wBZZnqgRLw</p> Edited by Rusty6 8/17/2013 21:01 (730 in June.jpg) Attachments ---------------- 730 in June.jpg (77KB - 1114 downloads) | ||
| Steiger Man |
Sunburst Montana | Neighbor has a 930 comfort king with the 6 speed and chain drive. Uses it for rock picking. Got it for $500 at an auction. He was proud of himself until somebody pointed out it didn't have a drawbar. No problem he just robbed a drawbar off of one of his LAs. I've looked it over pretty good and to me they look like a basic, simple, glorified Case 500, not high up on the technology ladder compared to IH, JD, and Oliver but probably cheaper and easier to work on. Edited by Steiger Man 8/17/2013 21:46 | ||
| detroitdiesel |
Chillicothe, Missouri | We have a few of the tractors, 1030, 930, 830, & 730. We use them for small jobs, and other light tasks. Several are a Case-O-Matic Drive. Which Works Really Great on a Wheel Rake!! just in converter mode, and just run at just above an idle! It works at an Amazing Level!! | ||
| Ed Boysun |
Agent Orange: Friendly fire that keeps on burning. | In the late 50s, early 60s, Case made a non Comfort-King 930. Hand clutch, 401 C.I.D. indirect injection diesel with an inline Bosch pump. Round fenders and you got on the platform from the rear, unlike climbing on the CKs via the front steps. Looked an awful lot like the last Case 900s. Ours didn't have power assisted steering, but rather a very large diameter steering wheel to give a little extra oomph to the turning. It was the first tractor our farm had that used duals. Wasn't a bad tractor and a step up from the IHC WD9s that were our main tractors at the time. The 930 was promptly traded when the AC dealer brought out a Series II D21 in 1966. | ||
| bb940p |
se wi | We had a 930 for a time. My wife took a magic marker and wrote Dis as a prefix to comfort on both sides of the hood. Needless to say, it got traded off not long after that. | ||
| farmerrob |
| I have a 930 and compared to the IH706 of the time they are much much better. The shifting is never an issue, the hydrualics are stronger, the workstation is bigger than the 706 and more comfortable. The dry brakes are probably the only difference I don't like the 930 better for. Much much easier starting. I don't miss the 706 one bit. | |||
| super90 |
53916 | Other than the wide orange fenders that first picture brings back memories. Dad had a single home made step that later got bigger for getting to the seat from the front left. Hourmeter said 0913.3 every time I looked at it from when I was just big enough to climb up until he sold it a few years after I was driving. It was an 830 diesel 8 spd. Pretty bare bones. Clamshell fenders, folded up sweet 16 bags for seat cushion, little power assist on steering if any. As tractors were upgraded by need more than desire, I fully appreciated a dual power Ford 8000 on the wagons over that 830 for filling ag bags with snaplage on a wet clay slope. 40hp and a few thousand extra pounds will do that though.... as well as a wide clear flat deck. | ||
| Bill Moyer |
Coldwater, Michigan | We had a couple 830 Cases, then a CK 830. Actually liked the non CK 830's better, they were a better balanced Tractor to handle. The CK 830 was however easier (Much easier) to get on to operate. The CK 930 and 1030' were a nicer tractor balance wise than the CK 830. You set in a different position on the 930 and 1030 than you did a 830. If I remember the CK 830' you sat on the rear axle, the CK 930's and 1030's you set just forward of the REAR axle. That seemed to give it a feel that you were a part of the tractor where with the CK 830 it seemed you were a part that was just stuck onto the top of the platform. The Cases would lug like 90 compared to an IH or JD of the time, but the JD were a nicer tractor to drive. We were IH people (3 M's and an H) and were looking to upgrade probably to a 706. Case dealer somehow talked dad into demoing a 64 830 diesel Case-o-Matic (non CK at that time). The 830 with 5-16 semi mounted ran over the 706 5-16 semi mounted that couple weeks. 706 was supposed to be a bigger tractor by about 10 HP than the 830, but the heavy clay soil pulling just killed the 706, couldn't reach for the Torque fast enough. When we took the tractors back to the dealers and told the IH dealer what had happened the IH dealer promptly put 706 on Dyno and found it was turning more than it was rated at. We bought the 830 and never regretted it. Later bought one more 830, then CK 830, then CK 930. Later in life I bought a CK 1030 rated at 108 or 110 HP, and the JD dealer where it was at said it would outdo any 4320 they had had in the field with it. Obviously the 1030 had been turned up but I put some hellatious loads on it and it just kept on going. They were not as nice to operate as the JD of the time but they were a workhorse. When all the rear ends were going out of the early IH 806's at about 200 hours we were glad we didn't own one of them. The IH probably looked better than the Cases, but I never thought they were easier to operate. Had a seed dealer when I was a DSM in Southern Ohio make the statement about his family's JDeeres: "They probably breakdown more often than a Case, They are harder to work on than a Case, They cost more than a Case, They cost more to work on than a Case,..... But they sure drive nice!" There was a lot of truth to that statement, particularly the last part of it! Edited by Bill Moyer 8/18/2013 19:20 | ||
| Search this forum Printer friendly version E-mail a link to this thread |
| (Delete cookies) | |
