Challenger 55 Good and Bad?
AaronJ
Posted 1/24/2008 10:31 (#291667)
Subject: Challenger 55 Good and Bad?
NCNE
Looking for another row crop tractor. Have found a couple 55's, these have 18" tracks and are wide gauge stance. Have had a genesis so the cab and tranny are very familiar to me, but was wondering about the rest of the tractor. What should I look for, being this is our first track tractor, beside the obvious tracks and bogeys. Powerplant? Final drives? What is the correct weight package for the tractor also? TIA AJ
plowboy
Posted 1/24/2008 12:33 (#291769 - in reply to #291667)
Subject: Re: Challenger 55 Good and Bad?
Brazilton KS
The downside of the tractor is the @#%# NH electrical system and hydraulics, especially before Cat took the #1 priority crap off and started using the valve stack like the big tractors. Outside of that, it's a good tractor.
If you intend to pull a 55 much, you need to put all the weight on which is allowed. It starts out about 10,000 lbs lighter then a 65 and not much lower hp.
graingrower
Posted 1/24/2008 14:07 (#291835 - in reply to #291667)
Carstairs Alberta
I have a 6nn serial tractor year 2002 the last ones. I t is a great pullin tractor yes the hydraulics are not as nice as they could be you have not a great deal of feathering feel but it is amazing what they will pull . Mine has all the weights front and idler you can hang . This spring was real wet in south central Alberta and i had just bought a new seeding tool and was wondering if it would pull it but it did great. T he tractor looks pretty small in front of 37.5 feet of 10 in spaced bourgault 8810 with mid row banders pulling a 4300 -300 bu. tank with a 1500 gal NH3 pup behind. I also spray with it on a 70 foot 3pt 500 gal. goes anywhere never taking the autosteer off even thru 3 feet of water amazing. You won't like the way it starts but you will like the way it sips fuel. in 3000 hours since new it has had a oil cooler gasket go out and a weird casting failure between the hyd pumps where oil started to leak thru a sand cast line but cat took care of 100 percent, parts look pretty pricey on some other repairs I have heard about
halfbaked
Posted 1/24/2008 14:52 (#291867 - in reply to #291667)
Subject: RE: Challenger 55 Good and Bad?
ask if it has the updates done to it. they should be able to run the serial no. and tell you what was done with the machine, depending on what year it is, probably a 1998 or newer with wide stance.
Cliff SEIA
Posted 1/24/2008 18:51 (#292054 - in reply to #291667)
What year are you looking at?  The wide track tractors were introduced in '97 with some updates made until the '99 model year when several changes were made and anything from a '99 to the end of production were all the same with all the updates.  I've been looking at them as well and I'll try to list the updates I can think of.
1.  The midwheels on the undercarriage were changed from a one piece spoked design to a two piece bolt together, Cat wants to sell the updated two peice design to replace the spoked but there is at least one company who can retread the spoked wheels so it would be a nice update to look for but not a huge deal.
2.  The track alignment adjustment (right behind the front idler at the bottom of the frame) was changed from an allen wrench style bolt to a regular bolt head.
3.  The rubber on the drive wheel was changed from a diamond tread to a chevron tread to clean out better in muddy conditions.
4.  There was an updated fuel tank, the original tanks were very prone to cracking and the updated tanks have two triangle shapes stamped into each side around where the lights mount, it's a $3,000 part from Cat so it would be a big plus to me.
For the '99 model year they made some bigger changes including but probably not limited to:
The hydrualic pump was increased from 32 gpm to 43 gpm and the couplers were improved.
The drawbar was changed to use a roller to swing on and the 3pt arms were changed to one piece cast arms.
I think that is also the same time they went from the smaller suitcase weights and the belly weights to the big suitcase weights like what was used on the big frame E series Cats.
I've spent alot of time talking to our local Cat ag mechanic and even looked at a neighbors tractor with him so I'd know what to look for and he said in general on those tractors you can get a good idea of the overall condition of the tractor by looking at the grille (if it's not cracked it's been taken care of), the tracks and the undercarriage.  If the sides of the guide blocks on the tracks are pitted the alignment is off but if they are pitted and glazed over they have "healed" themselves and it's not something to worry about.  Cat says new tracks can take up to 400 hours to get broke in and sometimes a new track will wear on the guide blocks like that until they get seated but when that happens they will get glazed over if that makes any sense.  At around 5,000 hours those engines will tend to need injector work but this guy said they have noticed that tractors using Cat fuel filters tend to go quite a bit longer before needing work than tractors using aftermarket filters.  If the serial number decal is missing off the frame it is also stamped into the frame ahead of the radiator where you can see it when you raise the hood.
Cliff SEIA
Posted 1/24/2008 19:25 (#292092 - in reply to #292054)
Subject: Here are some pics
This pictures show the two piece bolted together midwheels.
These are the older style spoked wheels.  In this picture you can also kind of see that it has the newer style fuel tank, if you look close above the lights on the side of the tractor you can barely see the outline of where the updated tank is stamped for extra strength.
dutch
Posted 1/24/2008 21:28 (#292256 - in reply to #292092)
West Texas
Cliff, the top picture with the chewed up little boogie wheels, that tractor has serious belt alignment problems. They should not peel of like that. I learned the hard way on ours. Shortly after we ended up replacing tracks.
Of course they were worn out but were also badly out of line.
halfbaked
Posted 1/25/2008 18:52 (#293079 - in reply to #292256)
same thing happened to my tracks on 55, they did not have the update done on alignment and it was froze/rusted tight.
