Search Forums | Classifieds (52) | Skins | Language
Case IH "HD"?
jowig54
Posted 7/25/2013 14:51 (#3228784)
Subject: Case IH "HD"?
Northwest Iowa
I should probably know this but what does the "HD" mean on some of the Case IH Steiger model numbers?
bigfarmer1486
Posted 7/25/2013 14:55 (#3228791 - in reply to #3228784)
Subject: Re: Case IH "HD"?
Ringwood, IL (NEIL)
Heavy duty. I've only seen it on the steigers. I think it adds a tow cable and other beefed up components. I think these models are what are used for scraper work. I'm shooting from the hip. No insider knowledge
youngsekfarmer
Posted 7/25/2013 14:57 (#3228795 - in reply to #3228791)
Elsmore, Kansas
I believe that's pretty much a spot on.
Grease
Posted 7/25/2013 15:29 (#3228849 - in reply to #3228795)
North Central Illinois
Bigger axles and a heavy duty transmission. The kicker here is I think you can only get the HD model they do not offer the standard. So if you think about it, Case is up selling farmers to use scraper models in row crop production.
bswenseth
Posted 7/25/2013 16:06 (#3228905 - in reply to #3228784)
ND
There are 3 versions of the Steiger: Standard, HD, and Scraper. The heavy duty is more beefed up as the same hp standard version. like the 485 standard has an inboard 4-planetary and the HD has an inboard compound planetary. The Scraper tractors have heavy scraper axles, heavy duty drawbars, built-in frame weight, and standard equipment is differential locks, backup alarm, tow cable, and beacon lights. They are also ROPS and FOPS Certified.
CIH8010
Posted 7/25/2013 20:38 (#3229378 - in reply to #3228784)
The HD is the old standard. They actually made a lighter axle and called it the standard. Started this with the tier 3 units. Scraper tractors use the hd axle,scaper drawbar, and a little different trans software. I have know idea what inframe weight is. Never seen it. Standard axle seem to hold up ok. You don't see many of them.
