AgTalk Home | ||
John Deere Field Cultivator Sweeps “Suck” Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
ads-pipe |
NC Iowa |
These have less than 1,200 acres on them and at least 7 of the are “Cracked and Broken” Two of them are Gone. Don’t worry John Deere, I will find them I am sure, with a tire!! Had 17 Cracked ones Last year and Dealer said they “Had a Bad Batch”. They never did anything for those so I won’t ask on these. Easier to just buy elsewhere What Brand should I go with? John Deere 980
(2013-06-02 11.44.36.jpg) (2013-06-25 16.36.38 (Medium).jpg) Attachments ---------------- 2013-06-02 11.44.36.jpg (61KB - 829 downloads) 2013-06-25 16.36.38 (Medium).jpg (33KB - 794 downloads) | ||
pharmer79 |
EC WisconsiN | They are warrantying this batch. BUT will not give you nuts and bolts. Told them not my problem, you decide if you want my future business over some nuts and bolts. I have had problems with more than 9. Made in Mexico don't mean what it used to | ||
Maple Leaf |
I had a new cultivator last year with knock-on sweeps and had same cracking problem and was told same thing "Bad Batch" and same service as you. I bought a new batch this spring and have not had an issue so I will keep buying from Deere for now. I also have a Sunflower cultivator where the sweeps don't crack just wear out alot faster then the one from Deere. I know you can buy cheaper sweeps but remember you get way you pay for and I am not crazy about having to change sweeps twice as much. | |||
craigseia |
fairfield ia | Gave us warranty on the whole machine, but said that the new batch had no warranty if you put them on with an impact. Good luck with proving that was my thought. | ||
150 farmer |
Pontiac, IL. | We have been using Nichols sweeps for years, Last about 1 1/2 times as long as Deere and a little bit cheaper. (I think)--- not sure on price, cause not using Deere anymore, | ||
69roadrunner |
North of Iowa | John Deere sweeps are not worth putting on, they are junk. | ||
Cyjd |
Good luck with Nichols knock offs | |||
Isaiah |
NWOH | CYJD...you mind explaining what you mean by that comment. | ||
bakerna4 |
Waldron, MI | Unless that's a 60' field cultivator I think you should feel pretty good getting 1200 acre out of sweeps. I don't think we get half that with a 30'. I've used Nichols and Deere and in my experience the Deere last longer. | ||
MGfarms12 |
South Western, IL | Nicholas shovels here too.... | ||
150 farmer |
Pontiac, IL. | I was wondering the same thing. Was that a sarcastic comment. or a truthful one??? FWIW we use the bolt ons. | ||
tj_farmer |
NW central IL | i think im running nichols ultra wings now. seem to be holding up well | ||
150 farmer |
Pontiac, IL. | HOW can someone say how many acres they get on a set. Is this an average?? We probably go through 2 or 3 shovels behind the tractor wheels to 1 shovel where there is no wheel track. | ||
wbstofer |
North Central IN | +2 on Nichols | ||
deere8400 |
NORTHERN IOWA | never had a problem with jd on 980 | ||
Dennis SEND |
I got a new 50' 2210 and put 1/2 Nichols ultra wings on and the other 1/2 and almost identical sweep that CFC Distributors is selling both wore excellent actually can't say either one is better than the other but the ones from CFC do have a slight price advantage and they are made in the USA. Another thing I found unusually was every sweep is wearing almost identical, I could take them all off throw them in a pile and you would never be able to figure out which ones came from wheel tracks, I had always been running Deere perma-locks before and these are wearing much better went over about 1800 acres and for the first 1000 conditions were pretty dry and they still wore very well, I would say there is about 50% of the sweep left, however I am assuming the second 1/2 will go faster but none the less they are still doing very well vs the Deere ones I ran before. These are the first time I have not wore out at least 2 shovels in the wheel tracks vs the rest of the FC but it is also my first season pulling the FC with a Quad Trac so maybe there is something to the reduced compaction from the Quad Trac vs a wheeled tractor. Edited by Dennis SEND 6/25/2013 21:21 | |||
mac4440 |
I've had ones on a CIH do the same thing. Found two laying in the field a week ago, they were shiny and caught my eye. Also have a DMI TM II that has 2 or 3 cracked ones on it now. Too much impact wrench? Edited by mac4440 6/25/2013 21:30 | |||
TMX864 |
Michigan | U guys make me sick!!! We are crawling under our 50' sunflower every 150 acres, or less if its dry, changing shovels. I would think I've died and gone to heaven if we got 1000 acres a set! | ||
JT_4_JD |
Nebraska | They wear even unlike the Deere sweeps and little to no cracks. Deere sweeps narrow as they wear. | ||
krantz |
NM | I get about 4 seasons ( 2 years ) on my 30' 726. About a thousand acres per season. | ||
SEMN John |
Hayfield, MN | FWIW... | ||
beachfarmer |
North Central MN | No kidding! We're lucky to get 150 out of a sweep. | ||
senorthdakota |
Ultra wings is what we use. | |||
bakerna4 |
Waldron, MI | That is true its hard to say what how long a set will run. I was just generalizing. We never change all of them at the same time. Seem the fronts wear faster than the rears and wheel tracks make them worse too. 1200 acres just seems like a lot to run on a set to me. I'm sure soil type effects this greatly. | ||
Tired of Working |
Central Sask. RM#254, Canada | Has anyone figured out how many acres you get PER SHOVEL ?? Makes a big difference if one machine is 30ft. and the other one is 60 or 84 ft. You get more wear on 30 shovels doing 1000 acres than 60 of them on same 1000 acres...Also the wider the machine the more efficient it is because of less overlaps ... At least that's how I was taught to figure it. Try doing 1000 acres with a 12ft cultivator behind a John Deere D. That's what I started on when I was 9 years old , it was all I could do to snap that hand clutch in and out.... SEEMED like a fun job for the first summer... | ||
eight |
South Texas | 150 acres on a 50'? That's what, 4 hours? Think I get about 4000 acres out of a set on a 38', still don't even make one oil change on the tractor. | ||
jgry |
Argyle, MN | The nock-ons had a batch that would crack too. I put on 10 and found 3 cracked ones laying in the field. I returned all that I had left and they gave me new ones, hopefully from a different batch. No impact wrench used to install them. | ||
Cyjd |
nichols knock off sweeps....clip type not bolt | |||
ks8780 |
Jewell County KS | TMX864 - 6/25/2013 20:37 U guys make me sick!!! We are crawling under our 50' sunflower every 150 acres, or less if its dry, changing shovels. I would think I've died and gone to heaven if we got 1000 acres a set! So you change sweeps once a day???? I think I'd use something besides a feild cultivator or find some better dirt. LOL | ||
Itchy |
SW Iowa | I thought you were supposed to trade it for new when the sweeps wore out. But, I run CIH, so that "earth metal" is tough stuff. | ||
TMX864 |
Michigan | ks8780 - 6/26/2013 06:57 TMX864 - 6/25/2013 20:37 U guys make me sick!!! We are crawling under our 50' sunflower every 150 acres, or less if its dry, changing shovels. I would think I've died and gone to heaven if we got 1000 acres a set! So you change sweeps once a day???? I think I'd use something besides a feild cultivator or find some better dirt. LOL Yep. Usually every morning when fueling we will change some, id say about 30%. 150 is the average. Some areas we will run 300 acres and shovel will be ok. We also have fields that when the cultivator shows up after 150 acres there aren't any shovels left on about half the machine. And I mean that literally. Sand, stones, and dry soil wear stuff out. Chisel plow points are the same way. Every day and a half were changing them. Wish they'd make knock on 4" twisted shovels. | ||
EbertFarms |
had the same issue, dealer covered them under warranty, no issues at all since. | |||
redfarm |
N. IL | Switched from CIH OEM sweeps to Nichols. Seems like 2x more life. We had to replace the OEM CIH halfway through spring last year. New Nichols this spring ran full season and good part of next year by the way they look. | ||
(Delete cookies) | |
