Search Forums | Classifieds (81) | Skins | Language
how much psi 4-wheeler tires?
gostate
Posted 5/30/2013 13:32 (#3127398)
Subject: how much psi 4-wheeler tires?
western iowa
I used to run the tires on my honda 4-wheeler at 4 psi. Ive found this spring that I much prefer running higher psi when I'm scouting fields and riding the roads a lot. How much is too much? I think I'm at 10 psi right now.
milofarmer1
Posted 5/30/2013 14:00 (#3127426 - in reply to #3127398)
Subject: Re: how much psi 4-wheeler tires?
Texas/New Mexico Stateline
Wow that must ride rough! I can't stand any air in the tires hardly. I want just enough to make the tire stand up a little. Mine look like radials with a little "pooch" to them.
smartwick08
Posted 5/30/2013 14:01 (#3127427 - in reply to #3127426)
Minot, ND
6 psi roughly
ACobb4020
Posted 5/30/2013 14:06 (#3127438 - in reply to #3127398)
North Central, NC
I run 4 to 5 psi in mudlite XTRs on Kawasaki brute force
Tippmann98
Posted 5/30/2013 14:08 (#3127442 - in reply to #3127398)
I run about 5 psi on my Bighorns on my Brute Force
fox128
Posted 5/30/2013 14:10 (#3127447 - in reply to #3127398)
West Central IA
You're fine at 10 psi....but as others have said it must be a rough ride!
gostate
Posted 5/30/2013 14:32 (#3127480 - in reply to #3127398)
Subject: RE: how much psi 4-wheeler tires?
western iowa
Sure the ride is rough. But good handling on the road is what I'm after. Could tell a huge difference on the little bit of pavement I'm forced to ride on occasionally. I guess I must be tough :) Back to my original question, how much is too much psi?
pbutler
Posted 5/30/2013 15:00 (#3127515 - in reply to #3127480)
Macon, IL
Mine say 32 on the side, I am running 20. Ride is fine.
Big Ben
Posted 5/30/2013 15:21 (#3127545 - in reply to #3127398)
Columbia Basin, Ephrata, WA
I'm just happy if they're not completely flat.
JD fanatic
Posted 5/30/2013 16:02 (#3127595 - in reply to #3127480)
mw
I dont think your too much, but they may wear the middles out faster. If i remember correctly the tester that came with our polaris sportman's only go up to 7 or 8 if i remember correctly.
But as somebody else said, i'm just glad if there is air in all 4 of them. seems like they are always flat. I think i run about 6 or 7 in ours.
IowaNotiller
Posted 5/30/2013 17:12 (#3127689 - in reply to #3127398)
Iowa
All four of mine are slimed at 10psi. No flat worries.
granto
Posted 5/30/2013 17:30 (#3127716 - in reply to #3127545)
18c ditch system
Ben, was that called for?:)
mk2angus
Posted 5/30/2013 17:36 (#3127728 - in reply to #3127398)
NW Minnesota
I have a Polaris that has a suspension and air mine till I get a firm bounce when I hit it with my fist. Not a soft mushy one and not rock hard but a good firm bounce.
Newguy
Posted 5/30/2013 17:55 (#3127770 - in reply to #3127398)
Renville Minnesota
We have a former Mechanic that worked on snowmobiles and atvs previous to working full time with us.
He said  "you can run em any psi ya want, but the best killer of ATV tires is too much psi..,...  5-7 is about perfect for maximum wear"
Another quote about battery's for Atvs.    Fill em with the acid mix, then let em sit for 24 hours, then charge em.    Filling then charging em will kill the battery within a year.   We thought small battery's were junk untill he informed us that.
ECIAfarmer
Posted 5/30/2013 19:58 (#3127993 - in reply to #3127770)
East Central Ia, S. Waterloo
Newguy - 5/30/2013 17:55
Now I bet I know what ruined my last battery so quickly. The shop I got it at just said that was about the life of them, but then they like to sell batteries! Another old quote " To soon old, To late smart."
