Search Forums | Classifieds (2) | Skins | Language
CIH 5240 pto problem
Brian sepa
Posted 5/26/2013 06:04 (#3117890)
Subject: CIH 5240 pto problem
Lancaster County, Pa.
Yesterday I hooked my 5240 to the diskbine.  I turned the pto shaft from 540 to 1000.  I engaged the pto and it started fine but shut off after about 20 seconds. My first thought was that the sleeve inside had not come back the whole way when I changed the shaft but I don't think thats the problem. Messed with it for a while and most times it would not engaged at all but once in awhile it would engage for a short time and then shut off.  When it shut off the lever stayed engaged, it didn't automatically fall back to the off position like it does when you shut the tractor off.  The other odd thing is that I can't get the shaft reinstalled in the 540 position....it won't push in far enough to get the snapring in.  Any ideas????  Most of the symtoms make me think some sort of hydraulic issue, but the shaft not reistalling makes me wonder of something in the gearing is messed up.  It has hydraulic oil.  I never heard any alarming thunks, snaps or grinding noises.
Edited by Brian sepa 5/26/2013 06:06
Minnesotaboy
Posted 5/26/2013 07:42 (#3118001 - in reply to #3117890)
Subject: RE: CIH 5240 pto problem
SW Minnesota
When I switch from 1000 to 540 I have to turn the shaft to a certain spot before it will slide in far enough to get the snap ring in. Not sure why yours doesn't stay running
casetech
Posted 5/26/2013 08:51 (#3118155 - in reply to #3118001)
Subject: Re: CIH 5240 pto problem
Good chance the shift pins in the sleeve inside pto is gooffed up, that was a problem with them tractors. Fool with it somemore but pto may have to come apart.
scottpf
Posted 5/26/2013 10:02 (#3118329 - in reply to #3118155)
Agreed case tech,the pins that go threw the shift collar are probably broken. Pto needs to come apart and get repaired. Make sure you take a good look at the snapring groove to see if it is rounded any. Good time to put that in too.
