SW MINNESOTA | What are the differences between the magnum and a t8 new holland. I know the cab controls are a little different and new holland had super steer is there much else different? |
mount vernon, washington | Nh has longer wheelbase. |
southern mn | no supersteer on t8 |
Flora IL | Besides what they mentioned I cant think of anything else |
Charles City. Iowa | Biggest thing today Case Ih vs New Holland.Is look at the New Holland Growth Energy program.You can save big today. If you want to see how the program works look at my profile. Send me a massage. If you do not look at the Growth Energy program you over paid. We been in business 63 years and we have not seen any thing like it in 63 years. Growth Energy program will let you buy new less then used out there. I see it each day.If You to look at this program you save big time.The New Holland T8 and the Magnum they both come down the same line in the same plant in Wi.I say there 90% the same. New Holland is made to put more 3 pts on the front.Longer wheel base better rided. same engines , tran.and cab. |
SW MINNESOTA | Really I thought the did have super steer!! Will they still turn shorter than a magnum with the axel set forward? Can you get a suspended front axel on a blue one? |
North of Iowa | Yes you can get a front suspended axle. |
NCIA | If you go to www.caseih.com you can compare any make and model. The only big difference I can see between the 2 is wheelbase. The NH is 16 inches longer. I tried to find a number on turning radius and couldn't find one. The case website says the magnum has the tightest turning radius of any tractor in that class. The case probably turns tighter but I wouldn't think it would be a huge difference. Suspended axles are available for both and the supersteer axle for the NH was ditched a few years ago. |
| the magnums still use the drop box so they rev 200 rpm less than the new Holland that is the only other difference not mentioned here yet |
South central Minnesota | There are two different T8 series tractors. The T8010-T8050 and the T8.275-T8.420
Which series are you asking about? You have been getting answers to both series tractors and they are very different.
Mark |
Charles City. Iowa | New Holland now uses a gear box too. On new T8 |
