Search Forums | Classifieds (36) | Skins | Language
Isuzu Diesel engine in a MacDon swather
farmer61
Posted 5/3/2013 22:32 (#3078624)
Subject: Isuzu Diesel engine in a MacDon swather
Oklahoma
Anybody have any experience with the Isuzu diesel engines in the MacDon swathers? Wondering how they hold up. TIA
Fawazhay
Posted 5/3/2013 22:41 (#3078640 - in reply to #3078624)
Subject: Re: Isuzu Diesel engine in a MacDon swather
Northern CA
I thought they ran a Perkins Diesel engine?
budfarmer
Posted 5/3/2013 22:51 (#3078656 - in reply to #3078624)
Have 2700 hrs on mine. one unusual hiccup but got that fix. Engine surge was a injection pump timing issue. there was gearbox issues on 9000 series with the 90 degree one under the cab. version1-3 of the gear box are replaced by v5. v4 is upgradable to v5. v4-v5 have a comer industries tag, v1-3 donot have the tag. here is the info on a version 4 tag
Comer Code 9.327.100.00 Date Code D06 to B08
Oregon Farmer
Posted 5/3/2013 23:34 (#3078719 - in reply to #3078624)
Subject: RE: Isuzu Diesel engine in a MacDon swather
Independence OR
I have two 9352i models. We ave had no problems at all with them, and we ave about 1500 hrs on them or so. Mac don put the Isuzu engines in the late model 9352s because the had some sort of emissions issues with the cummins if I recall. My father in law has one with an Isuzu and two without. He says that the isuzu is a little Quieter and burns slightly less fuel.
Scott
sprayertech
Posted 5/4/2013 05:49 (#3078800 - in reply to #3078624)
Belwood, Ontario
Do you guys mean Sisu engines?
Redwrench
Posted 5/4/2013 07:51 (#3078957 - in reply to #3078624)
Subject: 9352i The i means Isuzu
You are correct that the 9352i has an Isuzu engine (not Sisu, that's Agco.) Old Man MacDon got PO'd with Cummins that year and hunted for another source of engines. The Isuzu's are good little engines. BUT-- service might be hard to come by. At the time they were introduced in the MacDon swathers, there were TWO Isuzu industrial engine distributors in the entire state of Texas-- one in Dallas and one in Houston. That leaves a whole lot of empty when it comes to service on harvesting equipment. You might want to see if somebody in your area can work on them before you take the leap.
pudding
Posted 5/4/2013 08:37 (#3079057 - in reply to #3078624)
Somewhereville, Earth
dunno why service is going to be a issue, this is 2013
Orin
Posted 5/4/2013 09:33 (#3079142 - in reply to #3078624)
Nusbaum Farms LLC Bellfountain, OR
We have two of them, bought new in '05. They seem to be a reliable little engine thus far. There are a lot of Isuzu engines in this area, in the little cab forward trucks and in Link-Belt excavators. They seem to have a good reputation.
-Orin
Redwrench
Posted 5/4/2013 13:52 (#3079534 - in reply to #3079057)
pudding - 5/4/2013 07:37
Pudd, where you live, Japan-based Isuzu might be a big player. Not so in North America agriculture, although they make a fine engine (I happen to own one in my 2005 Chevrolet diesel) They have made inroads in the NA marine diesel market, are used in several brands of construction equipment, and I see a fairly good irrigation dealer network in Arkansas and to some extent the irrigated agricultural markets in Colorado in this region of North America. Just to be fair to Isuzu.
However, in reply to your comment......Hmm... let's see...since the first year that we (MacDon dealer) saw an Isuzu...(searching Isuzu dealer locator website: https://www.isuzuengines.com/distributor_network.asp) Yep, your're right! We now have an astounding 7 Isuzu industrial or OEM dealers in Texas instead of just 2 (not counting marine dealerships or multiple dealerships in the Metroplex cities.) That means if you are in, say, Lubbock TX it's now only 295 miles one-way to the closest Isuzu service center in El Paso, 319 miles to Albuquerque NM, 319 miles to Ft Worth, or 348 miles to Oklahoma City OK. I'm sure any of them will drop what they're doing and come running to Lubbock if anybody needs them. Yep things have sure improved a lot in 2013.
My point is make sure you are willing to live with possible breakdowns & down-time. These are very good engines, but they were designed, built, and are maintained by human beings... they're not perfect.There are a lot of things on the 9352i engine that can be repaired by any good diesel technician with common tools...and there are several things that are going to require the Isuzu tech manual, Isuzu special tooling, and Isuzu technical support to accomplish. The 9352i's were mechanical. As MacDon introduced electronic Cummins & Perkins/Cat engines, the dealership and shadetree mechanics got locked out. I am mostly locked out of my common-rail Duramax engine when it comes to electronics, despite OBDII.
And for the record, we did have issues with an Isuzu engine that first year that were a real problem to resolve because of the warranty, the travel time & distance from the nearest dealer, the Isuzu dealer's work schedule, and the downtime to the customer.
Edited by Redwrench 5/4/2013 14:05
