Watford City, ND | I'm posting this for a friend -
Upgraded tractors for spraying - pulling a Summers Ultimate with a Raven 450 controller. We'd like to use the Pro 700 monitor to control autosteer and rate controls. Is this possible?
Tractor is a 9350 Case.
Monitor is Pro 700
EZ-Steer 500
Controller is Raven 450
Is it possible to run the sprayer through the monitor? What all do I need?? And I mean everything, from cables to brakets for the monitor....
Thanks |
Watford City, ND | pics
(IMG_1431[1].jpg)
Attachments ---------------- IMG_1431[1].jpg (28KB - 367 downloads)
Watford City, ND | controller
(IMG_1433[1].jpg)
Attachments ---------------- IMG_1433[1].jpg (34KB - 334 downloads)
roaming | The_Owl - 4/29/2013 20:04
Yes, assuming the 450 has a serial connection. FYI that is a Pro 600 in your photo, not a Pro 700.
You need a CNH cable 87732647, and a Raven cable 115-0159-822.
You'll also need Raven Control software in your display (V27 if a Pro 600, or v28 if a Pro 700). The ops manual for this software is 84420153. (It's a v26 book, but it's the latest, and the software really hasn't changed since v26.) |
Dodge County, WI | If I am inputting GPS Into the afs wiring harness for our 600, how does a guy get the rate controls into the back of the Raven?
Ben |
roaming | the 600 and 700 have 2 serial ports, so you can use one for GPS and one for rate control. |
