 Ontario Canada | Have a bunch of willow and poplar trees that are a real pain and are getting into the tiles, was told that drilling holes into them on an angle down and putting roundup into them will get rid of them, anyone else tried this or is there a better way, would like to cut them down and pull out stumps afterwards, thanks for any ideas and help. |
NE Illinois | crossbow brush killer works great on willows, don't know about poplar trees though. |
 Grandfield, Ok. | Have heard that a few aspirin in the hole will kill a tree. Never tried it so do not know for sure. |
S.E. South Dakota | Tordon will kill them. |
nw pa | not sure if that will work. but for killing grapevines we hang a soda bottle full of round-up on a cut off branch.. few weeks later you can follow the vine. It's dying and after a month or so it's gone. Don't know why it wouldnt work on trees. Maybe use more than one bottle. |
East central Alberta | I drill holes and use 50/50 diesel fuel and 2-4d. |
Guelph, Ontario | Garlon 4 from Dow.
Follow label.
Not cheap.. but effective and legal in Canada.
Next best thing to an excavator.
| I had willows about 4 feet tall, I sprayed them with a standard 1% (1 quart to 10 gallons of water) solution of 4 pound glyphosate. I wet all the leaves, they died.
Cut stumps of lots of trees die when painted with tordon or crossbow. For spraying be sure to dilute by the label, killing sumac didn't work with a very strong spray of crossbow, it burned the tops off so fast nothing got to the roots so it came back three times. A proper solution killed it all, including the roots.
Gerald J. |
| brush killer and diesel or oil, follow label for basal treatment |
exit 220 I-80 IOWA | GARLON 4 REMEDY SAME PRODUCT MIXED TO LABEL FOR BASIL TREATMENT SPRAY ON BOTTOM 12---15 INCHES KILLS MOST WOODY GROWTH |
 Macon, IL | +1 on the tordon |
East Central Ia, S. Waterloo | IF you get the trees killed will the roots wash out? or will you still have to adress the tile situation some how? |
WC MN | Mix tordon with diesel and it will penetrate the trunk easily. |
 Ontario Canada | We just installed new tile this spring and don't want the roots to get into it, trying to prevent any roots from getting there. Will try some of the above replies, thanks all for the help. |
