Search Forums | Classifieds (105) | Skins | Language
Laser for dozer MANUAL grade control
inotill
Posted 4/4/2013 21:25 (#3013626)
Subject: Laser for dozer MANUAL grade control
Harlan, KY
Looking for a laser system for grade control for my dozer. Is there a laser system out there that I can just stop the dozer and look to see where the beam is hitting my blade?
Do not need an automatic, or want to pay for automatic control. Thought there may be something out there that is cheaper, and half way decent compared to nothing.
Thank you.
Todd P
Posted 4/4/2013 21:34 (#3013664 - in reply to #3013626)
Subject: RE: Laser for dozer MANUAL grade control
SE Nebraska
I put a laser from home depot (cheapo one) on a square tube on the dozer blade. The indicator flashes and beeps fast for up and slow for down (or vise versa) and continuous for on grade. If you cant hear the beep watch the arrows on the indicator and move the lever accordingly. Also used it on a grader to level a scale and on a mini excavator with a dozer blade to level a bin site to within a 1/4 inch without fill.
dondozer
Posted 4/4/2013 21:37 (#3013670 - in reply to #3013626)
Subject: Re: Laser for dozer MANUAL grade control
NW Ohio,near Findlay
We had a 360 degree receiver with a light system to tell you right on or high or low lights. Receiver had a very strong magnetic and we had a steel rod on each side of dozer blade. Others will advise on what brand name is good now.
Edited by dondozer 4/4/2013 21:38
Fingers77
Posted 4/4/2013 21:42 (#3013687 - in reply to #3013670)
YOu ought to pick up a Spectra Physics (Trimble) laser pretty reasonable. I think the 420 is a single slope unit with a receiver that has something like a 270 degree window and a magnet for mounting it on equipment.
Clay-All-Over
Posted 4/4/2013 22:30 (#3013865 - in reply to #3013626)
Eastern Ontario
Futurra makes a receiver that can be used on a stick to survey or mounted to equipment  ( magnetically ). It has an option for a remote display that you can put in the cab.  Saves you from getting off the machine.
Example:   http://www.lascolaser.com/product/Snap-Reciever-with-Display-All-Purpose-Sensor-with-a-40ft-Cable-for-Display_QitemCR5-RD.html
pullpin12
Posted 4/4/2013 22:43 (#3013892 - in reply to #3013626)
South central Ohio
http://www.engineersupply.com/Apache-Bullseye-3-Machine-Control-Las...
Now_What
Posted 4/5/2013 04:13 (#3014069 - in reply to #3013626)
Tremble - Spectra CR 600 comes with magnet mount and a clamp mount for your rod. Only problem is it only has photocells on one side so it really has about 200 degrees of coverage but it is cheep.
New link to manufactures site $350 - $400 price range unit
http://www.trimble.com/cr600.shtml
Edited by Now_What 4/5/2013 14:08
hillfarmer
Posted 4/5/2013 05:14 (#3014092 - in reply to #3014069)
Wonder how many "hits " that the Jersey seller is going to have ?
dixonman
Posted 4/5/2013 20:27 (#3015363 - in reply to #3013626)
I have a visable beam 945 spectra I would sell pretty reasonably if interested e mail in profile is good.
