AgTalk Home | ||
Case Skid Steer oil, HTO additive? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
caseihfarmer |
East Central, Nebraska | my case skid steer requires 10w-30 oil and it says with HTO additive, what is the additive. should i be able to buy the additive somewhere or is the additive a part of case' oil? i am a little confused about what i am needing here. the closest case dealer is 40 miles away and they told me they are not a case construction dealer and wernt sure of what i was talking about. they have to make me mad somehow every time i call there. Edited by caseihfarmer 4/1/2013 08:52 | ||
scott nelsen |
Leeds, North Dakota | What does ops manual say, its a lubricant for orbit motors, built into oil I believe, Scott. | ||
kawicat |
central wisconsin | It is only an anti-wear additive to bring the engine up to the specs needed to last the entire drain interval listed in your op. manual. You need 1 quart per 5 gallons of oil. $25.00 a quart. B17508 is the part number if you want to call ahead. | ||
farmboy8480 |
North Central Iowa | Our local ag dealer carries this but they also sell skid loaders too. | ||
ccjersey |
Faunsdale, AL | Been using tractor trans/hydraulic fluid in our 1845C's for about 20 years now. | ||
hagie man |
central IN | so what happens when you use premiun trans hyd fluid in the hyd system and good diesel oil in the engine instead of the 10 w 30 high dollar oil?? | ||
AJS |
NW Ohio | the additive is only for the hyd. system. i was told it is a anti foam for the system when used with the 10-30 ,, that what we have always used and we have 3 1840 loaders. | ||
Jon Hagen |
Hagen Brothers farms,Goodrich ND | caseihfarmer - 4/2/2013 07:49 my case skid steer requires 10w-30 oil and it says with HTO additive, what is the additive. should i be able to buy the additive somewhere or is the additive a part of case' oil? i am a little confused about what i am needing here. the closest case dealer is 40 miles away and they told me they are not a case construction dealer and wernt sure of what i was talking about. they have to make me mad somehow every time i call there. It adds etreme pressure additives to 10-30 motor oil so it is safe to use in hydrostatic drives. http://www.colemanequip.com/parts/CaseParts/B17508/513 Edited by Jon Hagen 4/1/2013 12:02 | ||
proud2Bafarmer |
Baldwin City, KS | I wouldn't not run it. | ||
(Delete cookies) | |
