Search Forums | Classifieds (64) | Skins | Language
NH FP240 with Kemper Head on Case 235 Magnum
CIH7777
Posted 3/25/2013 02:03 (#2989246)
Subject: NH FP240 with Kemper Head on Case 235 Magnum
WI
Looking at a used FP240 and I am considering to put a Dion F61 rotary 4 row-30" corn head on it. How does the Dion rotary head compare to the NH 3RN head? I am assuming the Dion head will last a lot longer for the $25K-$28K price tag I have seen on it compared to $13K for the NH head.
Also, would a Case 235 Magnum be able to handle the the FP240 with the F61 Dion Rotary head? The Case specs. show it puts out 195 PTO Hp at 2000rpm but I am not sure if this can be increased somehow. The NH FP240 requires 180-300Hp and I prefer not be on the low end of PTO Hp in case I need it in heavy crops.
JD4250
Posted 3/25/2013 05:20 (#2989280 - in reply to #2989246)
Subject: Re: NH FP240 with Kemper Head on Case 235 Magnum
eastern ontario canada.
3 rows will be fine 4 might be pushing it. nice thing with the dion head is you can take the rows you want
CCIL
Posted 3/25/2013 05:38 (#2989293 - in reply to #2989280)
WCIL
We have the same setup with the three row head and no kernel processor. Our corn wasn't the best last fall so really don't know how a four row would work in good corn but the three row worked fine with the 235. Like stated above you could take as many rows as you want with the dion head.
Edited by CCIL 3/25/2013 05:39
Minnesotaboy
Posted 3/25/2013 06:06 (#2989325 - in reply to #2989293)
SW Minnesota
I'm sure you could chip the 235 to up the power, dion head would be nice.
kwvnhfr1
Posted 3/25/2013 06:21 (#2989345 - in reply to #2989246)
Blue Grass (Eastern IA)
If you have a KP you will need more power, if not you will be fine. KP will take 50HP.
durallymax
Posted 3/25/2013 06:53 (#2989403 - in reply to #2989246)
Wi
Id stay 3 rows with the lower power. You dont want yo be at the top end of their range if you dont like fixing. We ran 2 FP240s for a few years before finally going to a self propelled. We would get one new one every year due to wear. We ran an 8940 turned up yo 280hp and an mx255 with a chip. KPs would like to fly apart, other smaller parrs in the drivetrain as well then when thr curterhead would break we would trade them.
Make no mistake, they are the toughest pull type out there, we just ran ours very hard. We did 500acres of hay per crop atbthat time and the same in corn silage.
behog
Posted 3/25/2013 08:48 (#2989682 - in reply to #2989246)
frederick, MD
We used to run 900 choppers with the new holland 3 row head. Best head ever made. It will cut any direction without spending the money on the dion. It will also cut grass, weeds, down corn, and need very little maintance. We ran ours for years, don't think we ever did anything to the head.
ayrporte
Posted 3/25/2013 09:58 (#2989853 - in reply to #2989246)
Eastern Ont
I think the Dion head is a good idea but at 25K take a long time to justify
We are running an 892 with a 3 row head and Horning processor,
Didnt see that much of a difference when we put the KP on,
redstar
Posted 3/25/2013 10:21 (#2989906 - in reply to #2989853)
eastern canada
Mag235cannot be chipped. No chip really work with it so far, it only uses more def with gaining very little hp.
ayrporte
Posted 3/25/2013 10:39 (#2989949 - in reply to #2989246)
Eastern Ont
You are gtting stresssed out by the HP requirment numbers AN FP 240 does not need 180 hp to just run it
The 240 should run easier then the 230, BUT will take the HP if you push it
FP 230 with 230 HP out front is running at capacity in CS, 2 row head rolls wide open,
limiting capacity is thorat area
Lot more parts to wear out on a rotary head
3 row head will slow your ground speed down easier on everthing less bounce It will also keep you at capacity all the time
4 row would slow you down more
If you want un matched capacity JF 1355/1360
https://www.youtube.com/watch?v=ZlBmzXihrSM
Dont know what they have for a corn head
Edited by ayrporte 3/25/2013 10:44
bsfarms
Posted 3/25/2013 18:54 (#2990876 - in reply to #2989246)
south central WI
I think the NH head is a great corn head. It does cut very well in all directions, much better than the Gehl it replaced. I looked at the dion and would like one, but not sure if it is worth it. The 8400 we pull it with dynos 270+. In haylage the throat/ head is the limiting factor. In corn silage it is the processor. I can fill a wagon with haylage quicker than with corn silage, but part of that is due to corn silage packing more in the wagon. I have disintegrated 2 lower front feed rolls, 1 each year we have owned it.
