AgTalk Home | ||
lovetoride650![]() |
USA&Belize | What hp am I looking at it has a super 10 trans behind it are these good engines? Would like it have at least 400-500 hp. | ||
ace![]() |
nw iowa | mine is set at 350hp. it gets about 7 mpg. not a big power house but get it up to speed it holds it well. 95 model should be past problems the 3176 had. ace | ||
John..neAR![]() |
![]() Caraway, AR | mine is listed as 335/365. I was told the 365 was with the cruse on. Not a 400, for sure, but it gets along. Haven't had much trouble with it. Water pump, and two injectors when I first bought it. Got about 700K on it. John | ||
4WD![]() |
Between Omaha and Des Moines, 7 miles South of I80 | 350 HP is the MAX HP sold for a 3176B engine.(9CK) {Edit: Maybe there was a 365 HP, with a software change???, that a dealer could install} Edited by 4WD 3/6/2013 07:05 | ||
John..neAR![]() |
![]() Caraway, AR | Here we go again. (PICT3188 (Medium).JPG) Attachments ---------------- ![]() | ||
sim1![]() |
central ND | if you never had the higher HP, you will never miss it, i have a 3176 in a 96 KW T600 runs great gets an average 5mpg. | ||
bpreuss![]() |
MN | we have 2 3176B with 9 speeds in 94 freightshakers set at 365 and one 3176 in a 95 freightshaker set at 350(reprogrammed) but the motor itself came from factory at 325 and everything about it is smaller. Oil cooler, radiator, turbo, etc.. they are a decent motor, got along fine for us over the years hauling grain and fert for us and custom, plus hauling 88,000lbs of beets. Not the most power or torque but they get the job done. | ||
4WD![]() |
Between Omaha and Des Moines, 7 miles South of I80 | Your engine is SOLD AS a 335 HP MT (Multi-torque) It does not have 365 HP in EVERY gear. It is either a MT-1 or MT-2 (I don't think they had MT-4; back then) Edited by 4WD 3/6/2013 17:39 | ||
IADAVE![]() |
I had one I really liked. If I got 6mpg I started looking because some thing was wrong. The one I had rewarded good maintenance. If any filters needed changed or the air to air needed cleaned the mileage would drop off. It was also very particular about oil level. Mine never uses a drop the 500,000 miles I drove it. I wasn't the one who put the first 500 on it either. I always seemed to get there as fast as the boys with the 500 hp engine. More than once I pulled the grade when they spun out because they had to shift and I didn't. I bought mine by accident while the mechanic was working on the engine. He asked me how I wanted it set. I told him I wanted the most hp I could get. He set it using " Marine Specs". If you can get some one to set it that way I suspect you will get the HP up where you want it. I also suspect if you use it 100% that way it might not last to long. | |||
durallymax![]() |
Wi | sim1 - 3/6/2013 07:26 if you never had the higher HP, you will never miss it, i have a 3176 in a 96 KW T600 runs great gets an average 5mpg. That must be a lot of short trips right? | ||
DAA![]() |
Sort of Central to North Central Iowa | Ours in a 91 IH 8100 is set at 310. | ||
(Delete cookies) | |
