Search Forums | Classifieds (76) | Skins | Language
Freeman balers in the morning..
granto
Posted 2/8/2013 12:15 (#2884080)
Subject: Freeman balers in the morning..
18c ditch system, winthrop Mn
This red baler comes complete with motor, what brand is it? Is this a good baler?
IHforever
Posted 2/8/2013 12:27 (#2884101 - in reply to #2884080)
Subject: Re: Freeman balers in the morning..
Davenport, Washington
Want to give us more to go on. Freeman balers are Red and white alright, is that the Red one you want to know about? No wonder people don't answer some posts here!
Edited by IHforever 2/8/2013 12:28
Joel Harman
Posted 2/8/2013 12:29 (#2884105 - in reply to #2884080)
N.C. Oregon
Very heavy duty balers.
granto
Posted 2/8/2013 12:49 (#2884151 - in reply to #2884105)
Unorthodox way of feeding system..
JohnW
Posted 2/8/2013 19:07 (#2884818 - in reply to #2884080)
Subject: RE: Freeman balers in the morning..
NW Washington
Their web page is not great but it says they come with different engines and Duetz, Cummins and even Wisconsin are mentioned. I did not think Wisconsin was still in the business. My guess is that Deutz are most common.
http://www.alliedsystems.com/freeman/380pt.htm
Jeff Outwest
Posted 2/8/2013 20:52 (#2885105 - in reply to #2884080)
Janesville Ca, 96114
They are pretty awesome balers
Does it look like these?
granto
Posted 2/8/2013 22:19 (#2885278 - in reply to #2885105)
Have feeling they are pulled buy a pickup often.
Fawazhay
Posted 2/9/2013 00:47 (#2885439 - in reply to #2884080)
Northern CA
I don't think the feeding system us unorthodoxed. I have eight of them. What would you like to know?
IHforever
Posted 2/9/2013 10:41 (#2886070 - in reply to #2885439)
Well Fazahay I just bought two 200t's and I wouldn't mind asking one question. Haven't run them yet but just rebuilt
the Wisconsin on one. Question: on the arm that swings to feed hay. On both balers the swing arm bearing is loose enough for the far end of the swing arm to start wearing on the curved tube underneath it. Is that bearing ajustable or do you just buy everything new. What about putting the torch to it and bend it up a little? TIA.
Fawazhay
Posted 2/9/2013 11:12 (#2886126 - in reply to #2884080)
Northern CA
No torch; no bending! It is probably not the bearing that has playin it, but the brass bushing is worn. Do you have a parts book? If not, go on ebayas they we usually there. Also, make sure you keep the bull gears well greased. You don't need to buy the expensive lube from Freeman; Cheveron makes a product that is very similar for about 1/5 the cost. Email is good if you have questions along the way. They are good simple balers
IHforever
Posted 2/9/2013 19:01 (#2886944 - in reply to #2886126)
Thanks Fawazhay I may take you up on the e-mail in the future and I'll go after that bushing in the spring time! Also thanks for the bull gear grease Warning!
I don't see your e-mail button though?
Edited by IHforever 2/9/2013 19:03
Fawazhay
Posted 2/10/2013 12:31 (#2888349 - in reply to #2884080)
Northern CA
I thought my email was in my profile. I will check. If not, "[email protected]"
IHforever
Posted 7/9/2013 09:05 (#3198865 - in reply to #2884080)
To Fawazhay from Joel Jahn here in Davenport WA. I would like to ask another question about 200 T's. I noticed some iron peices bolted to the front of my plunger. I am now wondering if that's why my bales don't have "ears" on the one end. Would a flat plunger face give me "ears" on that tail end? Would work better with ears for me to pick up with the stackcrusior> Thanks. I also e-mailed you this from my hotmail
Freeman fan
Posted 10/3/2013 22:31 (#3364051 - in reply to #3198865)
wasco, ca
You need those flat metal pieces to push the hay back far enough so the hay dogs can keep the hay clear of the needles when they come up to make a tie
Freeman fan
Posted 10/21/2013 01:16 (#3396138 - in reply to #3364051)
wasco, ca
attempting to show a picture of our balers and how we pull them around
(20131004_144227.jpg)
Attachments 20131004_144227.jpg (54KB - 475 downloads)
Freeman fan
Posted 10/22/2013 14:29 (#3398628 - in reply to #2885278)
wasco, ca
yep
