Search Forums | Classifieds (110) | Skins | Language
proper way to weld auger flighting to shaft
oakridge
Posted 1/27/2013 16:47 (#2853964)
Subject: proper way to weld auger flighting to shaft
West Central Wisconsin
I am building a cross auger for my strip till bar. I ordered flighting from shoup. The center hole is supposed to fit a 1" shaft but it is pretty loose. Should I use a larger shaft? what is the proper technique to weld the auger flighting?
Skipper
Posted 1/27/2013 16:57 (#2853994 - in reply to #2853964)
Subject: Re: proper way to weld auger flighting to shaft
You can stretch / twist them to make them fit tighter, not any easy task but that will probably snug it up. Watch about welding long beads as it can bow the tube. Most important weld is the top / discharge end.
white caddy
Posted 1/27/2013 17:24 (#2854059 - in reply to #2853964)
Central Nebraska
You need to weld 1 end and then tie a chain and come along on the other and stretch it until the flighting is snug on the shaft. Will probably have hit the flighting with a hammer a time or 2 to help out. Then weld roughly 1" beads at about every 2nd pitch. This is how we usually do it and works out quite well. Good luck
Boiler78
Posted 1/27/2013 18:28 (#2854239 - in reply to #2853964)
I think the distance between the flights should be the same as the diameter once you have it stretched.
Ellison
Posted 1/27/2013 18:33 (#2854260 - in reply to #2854239)
West KY
Boiler78 - 1/27/2013 05:28
Correct
ramlamb
Posted 1/27/2013 18:45 (#2854296 - in reply to #2854059)
Central NY
+1
stormchased1
Posted 1/27/2013 18:48 (#2854305 - in reply to #2854260)
south central Iowa
thats only true when the pitch is equal to the diameter, often its not.
150 farmer
Posted 1/27/2013 19:18 (#2854398 - in reply to #2854305)
Pontiac, IL.
+ 1 agree with stormchased1
PaKettle
Posted 1/27/2013 20:55 (#2854729 - in reply to #2854305)
Lenawee Co Michigan
The pitch should be the same as diameter or slightly less. If it's more the grain will start turning with the flighting instead of moving forward.
pupdaddy12003
Posted 1/27/2013 22:16 (#2854938 - in reply to #2854729)
NW Central Ohio
...I never put all the welds on one side of the shaft. I go about 1/3 of the way around the shaft (0r pipe) with each consecutive bead. If you put them on just one side..you'll have a very nice bow to your shaft when they cool.
Canadianfarmboy
Posted 1/28/2013 10:08 (#2855588 - in reply to #2854938)
East Central Saskatchewan
I made a jig for stretching the new flighting used an old piece of flighting minus the tube about 3 feet long, welded a piece of light angle to each side tied together with a light channel across the bottom. Tack the new flighting at the top, thread on the jig on the bottom use vice grips to attach to new flighting then using a bottle jack between the jig and the auger shaft you could gently/precisely pull the new flighting to a proper fit. The jig is buried in snow and I am a long ways from snow right now, but it worked very nic for me. Replace all the flighting on a Brandt 10 x 60 swing auger.
