Search Forums | Classifieds (199) | Skins | Language
Ford TW25 Pros & Cons
MAILMAN DAVE
Posted 1/14/2013 17:49 (#2822394)
Subject: Ford TW25 Pros & Cons
SW MO
Looking at a Ford TW25 MFWD anybody have any good stories or bad? Thanks for any information.
btaylor
Posted 1/14/2013 20:54 (#2823119 - in reply to #2822394)
Subject: Re: Ford TW25 Pros & Cons
southern ohio
we have a tw20 and I love it. would rather run it than our 4555 deere. cab is easy to get in, has great power and will lug forever. neighbor had a 25 with the electronic dash that quit working and ive seen a few others with dash problems but other than that i like them
260 AR
Posted 1/14/2013 21:03 (#2823161 - in reply to #2822394)
Subject: RE: Ford TW25 Pros & Cons
SE SD
Power steering system is weak so they don't make a very good loader tractor. 540 and 1000 pto is nice. I've got a 90 tw35 that i use to plant, spray, pull 500 bu. grain cart, and snowblower. Works good for me. The coolant filter needs to be changed to avoid problems with cavitation. As with any older tractor it depends a lot on how it was taken care of. edit easy to put 18.4 42's in place of 20.8 38's if you want to. Thats what mine has.
Edited by 260 AR 1/14/2013 21:09
(IMG_0755.jpg)
(IMG_0755.jpg)
Attachments IMG_0755.jpg (85KB - 802 downloads)
Attachments IMG_0755.jpg (85KB - 759 downloads)
buschman
Posted 1/14/2013 22:58 (#2823566 - in reply to #2823161)
Farming in Michigan
If you don't mind my asking, where did you get the 42" rims?
madcow
Posted 1/15/2013 07:30 (#2823920 - in reply to #2823566)
SCIA
I had one biggest pos I ever had More in repairs than I could add up.
260 AR
Posted 1/15/2013 07:54 (#2823987 - in reply to #2823566)
SE SD
They are just a step up rim made to go from 38 to 42 inch that will fit any red or green tractor. Got them from a local tire dealer. Just have to get the hardware from a non-power adjust ford tractor. Could take a few pics if you would like.
buschman
Posted 1/15/2013 21:08 (#2825723 - in reply to #2823987)
Farming in Michigan
No I've got power adjust rear wheels. Thanks for the offer though.
