Flora IL | Can u just take calls from it or can u also stream ur music threw them.
| I would also like to know this. A lot of our employees have smartphones that would utilize the Bluetooth capability to stream music. I would assume this is possible on these radios as well? Also where do u get them? Sorry to hijack your thread CaseFarmer just thought I would add a few questions.... |
Formerly NE North Dakota, now NW MN | I think you can stream music. One guy I work with has used it. I would prefer he not use it tho, because even in an 8320R (the quietest cab i've ever been in), there was enough background noise i had a hard time having a conversation with him.
You could probably order one from a deere dealer. keep in mind on a new install you'd probably be installing a mic. too. |
ND | You mean like this |
CMS | We have the factory John Deere set up in 2 of our r series tractors. I'm pretty sure with Delphi you can't stream the music wirelessly. There are a couple ways to hook the smartphones up by by the aux cords and the USB port. I have tons of music downloaded on a USB and is the best way to listen to music, I think. I don't like the location of the mic in the R series cab. I personally would put the mic under the radio instead of the front of the cab. |
 Sw Mo | Not a Delphi but how about something like this?
http://www.crutchfield.com/p_500CDE133B/Alpine-CDE-133BT.html?tp=56...
Put one in combine this summer and works great for hands free calling and streaming tunes. Whole lot cheaper than Delphi too |
Flora IL | Ya that works but you have to splice and any walmart bluetooth that says media streaming will do what im wanting... don't mind doing the wire work but would like just a common unit that plugs in and changes out easy between some vehicles.. |
