| Looking at snowpushers for my S 250. I think you could move alot of snow in a short time if it's not real deep. Have a 8 ft snow bucket now, but I think a guy could move alot more snow with one of these. I was thinking a 10 footer would be about right. TIA |
 central - east central Minnesota - | Unless a person is on hardscape pushing, I would rather have a snow bucket on a skidsteer. I have 3/4 minus rock topping my driveway, the snow pusher moved more rock then a bucket, even trying to hold it high. The skids wouldn't allow float, the scraped in. Keep in mind, the skid steers have more bounce and up down movement in them then a tractor loader.On concrete or asphalt, it's the cats meow.10 ft would be fine . . . . |
Leeds, North Dakota | http://www.erskineattachments.com/ AJ wheeled or tracked skid steer, landlord has a JCB 110 hp track machine with a 9 ft blade, even in hard snow its unbelievable how much it will push, do you have 2 speed that is a must, Scott. |
| I just bought an old 7 1/2' Western snow plow off a neighbor that I am going to adapt to our skid steer and probably add a set of wings too to make it about 9' wide. Worst thing about a bucket in snow is you spend so much time cleaning up the little windrows that go around the sides of the bucket, a pusher is going to reduce that problem alot. I paid $250 for my snow plow, will have about that much more in it adding angling cylinders and a crossover relief valve and wings are about $175. |
Central Minnesota | They work great on tar or paved surfaces. Not so much on gravel. I used to plow snow during the winter, and we had a few lots in town, and a 10 foot pusher. Worked nice on my S-250, and used it alot in the big lots. Tried it once at home and it wasnt bad. But the pusher we had was a Pro-tech, rubber edge snow pusher. Which the big rubber edge on the bottom instead of a metal cutting edge made it much better. But it still would grab some rock and gravel. The worst was by the bin site. We have some 1-1/2 red rock that ramps up to the cement by the pit and legs, and you never would want to use it around that. It would pick up alot of those rocks. Over pure gravel it wasn't just to bad. But you will have to tip it. So it's not diving in. I still prefer'd the big snow bucket though. |
 central - east central Minnesota - | NDFarmboy - 12/15/2012 00:19 Looking at snowpushers for my S 250. I think you could move alot of snow in a short time if it's not real deep. Have a 8 ft snow bucket now, but I think a guy could move alot more snow with one of these. I was thinking a 10 footer would be about right. TIA
If you really want to spend some money - look here, at Degelman's site. They have snow moving blade/boxes and more ! http://www.degelman.com/ Of course money is no object ? ; ^ )
For an economical consideration, here is Notch Mfg - http://www.notchmfginc.com/snow_pushers.htm#Snow%20Pusher They have snow buckets also . . .. . |
NE of Des Moines | I bought a used snow blade all set up for my skid steer. I used it a couple of times and took it off, its never been back on the skid steer. You know how you can use your bucket to help get "unstuck" well I couldn't quite manage that with the snow blade. Also a two speed tranny would be a great help, which I don't have, I just couldn't quite go fast enough to really roll the snow out of the way. So my 200 dollar purchase is being parted out for other projects. I just use my material handling bucket for light snow, and for heavy snow the snow blower goes on the skid steer. |
 Embarrass WI | I did that a couple years ago, it works pretty well. Bought a Western truck plow and mounted it on a skidsteer plate.
If you do that, try to set up the pin pivot point about the same height as it would be on a pickup with your loader all the way down. I put the pivot near the bottom of the mounting plate, and I have to run with the loader slightly lifted for the cutting edge to have the right angle. It would be better to push off the frame of the skidsteer instead of the hydraulics. |
| I have used a bucket, snow pusher with rubber edge and snow V-plow. For me, I rank them in that order for usefulness and speed. Unfortunately, it is the same rank as cost. I used them on gravel and cement. I try to stay just above the surface on the gravel or you just scrape too much gravel off. I also pile my snow on the gravel. Then come spring, I can move it back where I need it with the blade. Important tip: don't put the snow on the wife's grass.
The v-plow can act like a pusher or angle blade and really works fast.
A pusher moves a lot more snow than a bucket. My pusher is almost 3' tall in the back and sides. Rubber edge is nice and will not tear up you cement and leaves the gravel alone. The edge is 1.5" think and surprisingly durable. I also have a rubber back blade on the front to pull snow away from buildings, steps or garage doors. Mine is an 8' virnig. http://www.virnigmfg.com/index.php?page=shop.product_details&flypag...
Your S250 should handle a 10'. |
| Scott, I have 2 speed with wheels. My driveway is paved, but do have alot of graveled areas around bin site and other areas. The ground gets pretty hard so was thinking rocks wouldn't be that big of an problem, but maybe it would. Still in the thinking mode ! |
| We have a pusher and justs got a bucket, I am thinking the bucket will be used more. |
| I'm thinking on using the pusher for the big areas, and the bucket for final cleanup around stuff. |
| Solid pushers
http://www.holmeswelding.com/snowdozers.htm |
Leeds, North Dakota | Yes ground need to be frozen, set skids where you want it, I have gravel here, not any issues, Scott. |
 North central North Dakota | I have three units that I can use for snow work. 90" Heavy Duty dirt bucket, 9 foot snow bucket and 10 foot Protech snow pusher. All can be used on either the John Deere 6430 or the Bobcat A300. For most of the snow removeal the Snow pusher works the best on the Bobcat or John Deere. There is no need to "tip" the bucket when making piles and it is amazing how high of pile can be pushed up. No digging up of sod or rocks with the rubber cutting edge of the Protech unit. The 9 foot bucket works well on Bobcat when I want to move snow, can pick up and haul the snow to a different spot, or pull away from a buiilding and scrape down to surface at same time. Dirt bucket work nice in tight areas to clean up and work down to gravel.
The all wheel steer works very good when pushing snow, I tried to use skid steer mode and had a very hard time pushing piles and steering to get snow pushed in right spot. Seems to me the articulated steering makes a nice way to turn while pushing. Doesn't tear up the ground as bad if it is soft also. I have a 8 foot 3pt snowblower on the 4450 for big snow removeal also. The 6430 loader has been converted to accept skid steer buckets.
Attached pictures.
(IMG_1702b.JPG)
(IMG_0830-1b.jpg)
(IMG_1880b.JPG)
(IMG_1697b.JPG)
Attachments ----------------
