Search Forums | Classifieds (4) | Skins | Language
Is there a difference between kerosene and #1 dyed fuel?
GregChuckles
Posted 12/2/2012 21:29 (#2729472)
Subject: Is there a difference between kerosene and #1 dyed fuel?
Went to town with the service truck the other day with fuel tank on and pulled into a fuel stop that I normally don't go to, thought I would fill up with #1 dyed. Found the red dyed fuel pump and wasn't paying close enough attention but once I got to the counter I was rang up with #1 heating fuel/kerosene. I was shocked because it was .80 higher than #1 diesel which was at the same fill station and I grabbed the red kerosene handle instead. I never barked because it was my mistake and mine to deal with. I would suggest marking it clearer though, both have red handles #1 in big letter and diesel or kerosene in subtle small letters where one doesn't normally look. LOL
Anyway, is there a difference between #1 diesel and kerosene. I know it smells differently. And 2, is it alright to run in my equipment, etc?
Thanks
Why does crap like this always seem to happen to me? LOL
commissioner
Posted 12/2/2012 21:38 (#2729491 - in reply to #2729472)
Subject: RE: Is there a difference between kerosene and #1 dyed fuel?
southern Illinois
From the internet:
Fuel 101 by Richmond Laney
The difference beween Diesel Fuel and kerosene
The differences between Kerosene, jet fuel, #1 Fuel oil, #2 Fuel oil, heavier fuel oils, gasoline, etc. are the types of hydrocarbon chains that are separated and concentrated during refining and additives. For example gasoline has an octane rating which compares the gasoline blend with the performance of pure
octane hydrocarbon with eight carbon atoms. Diesel has a septane rating, please note that septane has seven carbon atoms in its chain. Octane rating is how hard it is to ignite and septane rating how easy it is to ignite.
What this all means is that the heavier fuels have longer hydrocarbon chains, higher BTU content, are thicker and are more tolerant of contamination (also they are allowed to contain more sulfur).
K-1 Kerosene, #1 diesel, and jet fuel (JP4) are closely related to each other. #1 and JP4 have higher allowable sulfur than K-1 (kerosene is also called coal oil by old timers). Since #1 is a shorter hydrocarbon blend it has better solvent properties than #2. (We used to clean out our armored vehicle engine compartments with diesel fuel in the Army, also gasoline used to be sold as petroleum naphtha as a cleaning solvent before it became a motor fuel.) It also has a lower gel point, which means that it takes a colder temperature to turn it to a molasses like thickness. Because these fuels are blends they don't
freeze like water, they act more like Jell-O slowly getting thicker until they set. This is why in cold climates it is suggested that #2 be blended with kerosene to keep it from gelling to soon. (Mercedes suggests using up to 30% gasoline in very cold climates).
In the US fuel oils are blended according to climate and location and there are also additives that control gel point, contamination (like water), change the flash point, to identify different uses (dyes) etc.
There is no real benefit to using kerosene /#1 over #2 unless you need to because of cold temperatures or you just want to clean out your system. If you switch to #1 please change your fuel filter to avoid clogging from any gunk removed. As it has been pointed out #2 has the higher heat (BTU) content.
All of this is good to know as in a pinch you can use diesel (or kerosene) in your furnace as a correspondent in Florida recently did during a cold spell when he couldn't get a delivery of fuel oil right away. (Conversely you can use fuel oil in your diesel car but the Feds don't like that as it is not taxed as
motor fuel, Several times I have put motor oil in diesel engines when I have run out of fuel.) Personally I would use whatever is cheapest for that area, temperature range and manufacturers recommendation. This means #2 for the most part.
Polar Bear
Posted 12/2/2012 22:34 (#2729637 - in reply to #2729472)
Subject: Re: Is there a difference between kerosene and #1 dyed fuel?
NE Indiana
Not sure where your at but here in the winter they blend kerosene into the diesel to help with jelling. They call it winter blend. In the truck is does lower your milage a little. Should be fine.
Dennis SEND
Posted 12/2/2012 22:41 (#2729661 - in reply to #2729472)
I have been told and pretty shure it is true that Deere puts kerosene into all new tractors/combines they build during teh winter months since they set outside in the staging area waiting for trucks to deliver them so they can be started easily, I beleive this is true because new stuff I have gotten that was built during winter months, the fuel has differnt smell to it. Assuming this is true I think is is a good idea as it allows diesel equipment shipped in cold weather to be started with out the use of a starting aid, pretty shure the only down side you will notice is the lack of power as kerosene has less BTU than even #1 fuel (I think) but it burns extremely clean thus the reason many people use it in knipco type heaters in buildings.
jr80
Posted 12/3/2012 10:12 (#2730385 - in reply to #2729472)
NECIL
I would say there's not much difference. I used to haul fuel out of the Citgo terminal at Lemont, IL and K-1, #1 clear and #1 dyed all came out of the same load spout. The difference in price is usually dependent on the taxes, or lack there of, and/or what the terminal classifies their product as on the bill of lading. Kerosene is more expensive than plain old #1. I know some of the route drivers I hauled for would just sell #2 high sulfer for hearing oil just cause it was cheaper. I know Marathon and a few others used to classify fuel oil and diesel fuel differently. They told us that fuel oil, #2 and #1, didn't have the additives that diesel fuel, #1 and #2. But I don't know if that difference exists anymore with ultra low sulfer diesel fuel. I believe all fuel, #1 and #2, is ulta low sulfer now and is given lubrication additives except kerosene.
