Search Forums | Classifieds (76) | Skins | Language
John Deere 5085M
Steve F
Posted 10/22/2012 17:17 (#2654886)
Subject: John Deere 5085M
Osceola, NE
Looking at a 2012 John Deere 5085M MFWD with a 563 Loader. Very nice units with less than 100 hours. I think? it will replace a John Deere 4020 w/Loader. I know the loader will not have the lift capacity that the old loader had, but dealer said it will easily handle seed boxes (2500+Lbs).
The 5085M will have a cab which I really need(want?). The main use will be seed/chemical pallets, shredding and show removal. I think if I buy the tractor I will look for a smaller 3Point snow blower. Just wondering if anyone has one of these tractors and how they like the unit.
Any thoughts and/or recommendations will be appreciated!
chief1403
Posted 10/22/2012 18:00 (#2654937 - in reply to #2654886)
Subject: Re: John Deere 5085M
s.e.mn.
Run , fast
EbertFarms
Posted 10/22/2012 18:39 (#2654973 - in reply to #2654886)
have a 5055E and is a handy driveway maintenance tractor, reshaping small waterways with the box scraper, etc. tractor.
It will NOT comfortably lift a pro-box, with the forklift attachment it sticks out too far. Had 8 suitcase weights hanging off the back 3pt and was still very tippy, dad thought i was going over on my side.
Buy a forklift if you want to move seed boxes, chem totes, etc.
Omar
Posted 10/22/2012 19:42 (#2655088 - in reply to #2654973)
Elmira, Ontario
5085M is a lot larger than your 5055E.
EbertFarms
Posted 10/22/2012 20:02 (#2655139 - in reply to #2655088)
a 563 is a 563 regardless, they have the same hydraulic flow. It wasn't easy to lift a probox off a gooseneck by any means.
cotton880
Posted 10/22/2012 21:14 (#2655362 - in reply to #2654886)
Subject: RE: John Deere 5085M
Elkmont, AL
We bought a new one in january and use it in our chicken houses, which is an extremely harsh environment. So far I really like it compared to the 5320 it replaced. Hydraulics are kind of whiney, and I have serious doubts about it comfortably lifting a probox comfortably. But knock on wood no problems yet. I really dislike the new cartridge style air filter, it says your not supposed to blow it out but if I didn't I would have to put a new filter in everyday running in chickenhouses.
Omar
Posted 10/22/2012 22:19 (#2655554 - in reply to #2655139)
Elmira, Ontario
I can't say I've ever seen a 563 on a 5055E open station tractor. I just assumed you had meant the 553. I couldn't find a mounting frame option to fit the 563 to a 5055E when I double checked old price lists.
tink
Posted 10/23/2012 01:13 (#2655934 - in reply to #2654886)
I have a 5105M(2011, open station) w/563. With pallet forks, I've lifted ~2500#. The problem is not the hydraulics - they're fine - but the distribution of weight. I cannot recommend the tractor for this work. You can easily resolve it for yourself by having the dealer load a pallet and trying it out. Do not make any sharp turns - no point in taking unnecessary risks.
Westendorf
Posted 10/23/2012 09:21 (#2656281 - in reply to #2654886)
I suggest the dealer swap out that loader for one that WILL handle the seed boxes...
http://www.loaders.com/userdocs/selector/JD-5105M-4-TA-26PLUS.jpg
or for added lift height to 12' you could consider http://www.loaders.com/userdocs/selector/JD-5105M-4-TA-26-12.jpg
Edited by Westendorf 10/23/2012 09:21
