Search Forums | Classifieds (14) | Skins | Language
Case IH 7120 Transmission
greenacres
Posted 11/4/2007 18:29 (#232057)
Subject: Case IH 7120 Transmission
Canada
I have a 1992 7120 with the 4 speed reverse trans. I am having 2 problems. First when I shift from neutral to either 1 or 2 reverse the tractor will move back about 2 feet even with the clutch pressed. Second problem I can't shift into 3 or 4 reverse. If I force it and get it into 3 or 4 the tractor won't move. It seems like it is still locked in park. Any help is much appreciated.
Virginia Veg.
Posted 11/5/2007 11:53 (#232512 - in reply to #232057)
Subject: Linkage
Eastern VA. No such thing as too many Magnums.
It sounds to me like your speed linkage is mis-adjusted. When you move the lever from side to side in neutral, it shouldn't move. Try this, release the clutch and move to forward neutral. Does the tractor move and the dash shows forward 1st gear? If so you just need to adjust the cable a little bit. As far as the 3 and 4 reverse is concerned, you have to come out of park and go all the way to neutral before you select 3 or 4 reverse. You can't go from park directly to 3 or 4 reverse.
Edited by Virginia Veg. 11/5/2007 11:54
greenacres
Posted 11/5/2007 12:20 (#232525 - in reply to #232512)
Subject: Re: Case IH 7120 Transmission
Canada
Thanks Virginia Veg. Yes I know about going to neutral before 3 or 4 reverse. The only way I can get 3 or 4 is to reach between the shifter and manually hold the park linkage back to neutral. Any thoughts??
Virginia Veg.
Posted 11/5/2007 19:25 (#232665 - in reply to #232525)
Man Jeff,
I just don't know what to tell you. I can't remember what it looks like under there. I had to put a new F-N-R cable on our 8950 in April, but I can't picture it in my head right now. I need to adjust it sometime because ours is difficult to get any of the reverse gears. I got the cable a little too far adjusted one way. I might take the cowl off tomorrow, if it rains tonight, and I'll get back to you. There is a little cable that pulls the machine out of park when you pull the lever back, but if I understand you correctly, the tractor is only giving trouble when you try to get reverse? Anyway, I'll attach a picture of the park cable, could this be presenting a problem?
(MagnumParkControlCable.jpg)
Attachments MagnumParkControlCable.jpg (47KB - 661 downloads)
greenacres
Posted 11/5/2007 19:37 (#232673 - in reply to #232665)
Canada
Part #1 is the item I was referring to pulling back to get into 3 or 4 reverse.
red mechanic
Posted 11/6/2007 21:52 (#233308 - in reply to #232057)
Subject: RE: Case IH 7120 Transmission
Make sure bolt number 4 in the parts picture hasnt backed out.
