How many bushels does a JD 9400 with Maurer Bin
Mudpie1971
Posted 9/26/2012 21:30 (#2610409)
Subject: How many bushels does a JD 9400 with Maurer Bin
How many bushels of soybeans does a JD 9400 with Maurer Bin extnesion hold assuming an average test weight.???Thanks
Brad9410
Posted 9/26/2012 21:37 (#2610420 - in reply to #2610409)
Subject: RE: How many bushels does a JD 9400 with Maurer Bin
Warren, IN.
We have a 9410. Same bin extensions. Should be around 220.
Ron (Cen. IL.)
Posted 9/26/2012 21:47 (#2610449 - in reply to #2610420)
Central Illinois
I'll have to disagree, I'm going to say around 280. I think I've had close to 300 on before (wet bushels). The owner's manual says 182 for the standard grain tank, i think Maurer's site gives the standard extension (without the extra tip-top) as an additional 100 bushel.
tomosakis
Posted 9/26/2012 21:58 (#2610481 - in reply to #2610409)
Subject: Re: How many bushels does a JD 9400 with Maurer Bin
Osakis, MN
250 to 280 depending on how smooth you are at pulling the hydro lever to neutral!
ISACC
Posted 9/26/2012 22:13 (#2610538 - in reply to #2610409)
NW OHIO
9410 with maurer heaped full 280 bu.
Brad9410
Posted 9/26/2012 22:16 (#2610550 - in reply to #2610481)
Warren, IN.
No yield monitor. Never caliberated the auger bushel sensor either. Ours all goes to the mill in dry bushels! We have had the combine 5 years now and was going by the previous owner in saying he thought heaped was 230 with corn. I sure dont think we have had that much on at a time.
Brad9410
Posted 9/26/2012 22:31 (#2610603 - in reply to #2610538)
Warren, IN.
Well sheet! We aint filling her full enough then. Lol. We put 16.9 tires on the rear in 2009 I think when it was muddy as heck and it sets the back end up pretty well. Its starts rolling to the front pretty quick when it gets heaped up. We dont use the cab for over flow!
John e.c.MI
Posted 9/26/2012 22:53 (#2610671 - in reply to #2610409)
Croswell, Michigan
You can get 250.
jd-tom
Posted 9/26/2012 23:52 (#2610804 - in reply to #2610449)
SW Minnesota
+1. That's what I read about it also when we got ours about 6 years ago and I know if we fill it plumb full with corn it is close to 300 bushels. (That's with going up there and pushing it into the corners by hand so we could make it to the end a few times!) That really requires a steady hand on the hydro lever!
